Author Topic: 1976 F100 stepside 4000lb, iron headed 390, solid flat tappet, transbrake, etc  (Read 52570 times)
bluef100fe
No the one time I went to the track with the big one in we got rained out last fall
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
A video link to my office view from the annual all ford memorial race in hardinsburg KY at US 60 dragway last weekend.. Where the mistress ran a new best ET of 7.29 @ 91.73 mph with a 1.535 60 ft. Got it going nice and straight now, for the last 20 or so passes, then the old Yukon 31 spline axle gave up on me, now I'm forced to install the completely new narrowed/back braced/disk brake/35 spline rearend housing I've been building
A link to my office view from the annual all ford memorial race in hardinsburg KY at US 60 dragway. Where the mistress ran a new best ET of 7.29 @ 91.73 mph with a 1.535 60 ft.
https://www.facebook.com/ladowski/posts/10211159388915006
« Last Edit: June 14, 2017, 06:24:35 AM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
Bolted to Floor
Nice office.
Nice Cody she's honking at that weight
bluef100fe
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
DUDE, if the quality is good enough you REALLY need to make that into a poster!! Super cool!!
Did he know what he was up against?..lol
« Last Edit: June 22, 2017, 06:31:54 PM by cjshaker »
ec164
Good Job Cody.....Al
You're ahead in a Mercury......all the way
bluef100fe
As most of you probably read already.  I got a new mill in the mistress. Blair gets most of the credit for the engine since it was mostly his recipe. I sent him a bunch of parts and he worked them into the combo. Anyway, the truck now has a new narrowed, back braced 9" rearend with vented/slotted disc brakes, 35 spline axles, and a big pinion 35 spline, 4.57 pro gear. 31.25 x 12.2W Phoenix tire on a 14" rim, leaf springs from LMC truck with custom fabricated by me spring hangers and brackets. Also added a 6 point roll bar and 5 point harness. Went to a treaded skinny street radial tire on the front for drag week last year that I didn't get to go to... it also has a sumped stainless fuel cell and stainless battery tray all hidden under the flare side bed. Anyway, with all the changes and myself losing 35 lbs the truck still gained and now weighs between 4050-4150 depending which rear tire and how full the fuel cell is. Last weekend at annual ford shootout memorial race in hardinsburg KY (US 60 dragway) the truck ran a new best of 1.43 60 ft and 6.53@104 mph. I haven't updated anything lately because I feel there is more left in the combo. In my mind there should still be a tenth or two to get yet if my new converter ever shows up from ATI... I could also buy another set of gears because I'm not optimized for the 1/4 mile yet much less the 1/8 mile. I'll update again if I have anything of good news to report yet this season... with my business being busy and moving/renovating a old building hasn't left me much time for playing at the track.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
BOutlaw
Wow Cody, huge improvement with the new "Blair" motor, almost a second. I have followed your truck ever since I started lurking this forum and your truck is what encouraged me to start running the Ranchero. Im 700 pounds lighter than you and my best to date is a 6.79, 1.49 60 ft. You got me worried now with your rear end failure. I just went to 31 spline, N case, Quick Performance chunk, 1350 yoke thinking Id be good forever. I don't have a transbrake and that may be the "failure" secret. As CJShaker mentioned, you need a poster of the recent launch pic. Regardless, please keep posting updates as Im sure theres more there and Im sure interested to see the even faster timeslips that I know are coming.
BTW, care to post any engine data? Cant believe you would still be running iron heads, but I believe Blair could make a shoebox work. Youre definitely making some power, maybe Werby can GONK that thing.
Brad Outlaw
bluef100fe
Here's a link to blairs engine build thread of my engine, it has a victor intake and a set of blairs edelbrock pro port heads on it... http://fepower.net/simplemachinesforum/index.php?topic=3999.0
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
WerbyFord
Cody,
FINALLY catching up on your ride.
A couple questions:
* I assume that 4050-4150 weight is INCLUDING you ??
* HEADERS: (Maybe for Blair) - what size headers were used on that 800+ hp dyno run?
The Gonkulator wanted 2-1/8 or even 2-1/4 diameter
Are you still running those little 2" diameter headers? If so they are way small. Gonkulator says as much as 60hp too small.
Most of your missing 0.1 could be right in there, plus a couple MPH.
A good demo of how much extra engine it takes to go "just a second" faster in the 1/8 mile.
Yours has to be the fastest FE truck around. Still. ;D
bluef100fe
Hey werby,
Good to hear from you. Yes I'm still running the same old 2" home built headers and 3.5 collectors and 3" x-pipe with cut outs  from years past... ironically the big engine only lost a tenth in the 1/8 from plugging the cut outs and running through the full exhaust... the torque converter is still too tight and I don't have enough gear in the truck for a optimum pass as I still want to drive it on the street. I thought my headers were too small also but Blair told me to only step them up to 2.125 and the appropriate collector. I'm working a lot on trying to get my business where I'm comfortable and happy then hopefully I'll have some time to work on the truck some more. Yes 4100 lbs going down the track. I'm looking into possibly changing the front suspension to struts and adding the rest of the tubes to make the truck legal to run faster than 10.0... don't know if or when I'd get there but I'm entertaining  the idea lol. Thanks
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
Well it’s been a loooong while but I finally made a little time to work on the truck and take it to the track… made a couple test passes, at dragway 42 for Tony Fritz’s fast ford event, and learned some things, after all this time the 520 continues to keep chugging along in the mistress. Borrowed a standard ratio trans from my buddy Scott, slid my nitrous converter in the truck with the intention of bottle feeding the truck some this weekend. They had two quick 8 races on the schedule one of them being FE only, along with a FE only bracket race, and they’re all ford no box class which I also entered. I didn’t believe it at first when they announced my name as qualifying for the fe quick 8… the bump was 10.14. the Transbrake wasn’t working on the truck so I was two footing it and grabbing the sassy button as soon as I could… probably 10-15 ft off the line, I was kinda worried about hurting the trans or twisting off the stock C6 input shaft. Everything survived thankfully and I drove the truck to a Father’s Day cook out Sunday afternoon. So I had 73 nitrous jet in the plate (smallest that comes with the plate system I won at the ford memorial race at US 60 dragway years back,and set the timing to 27 degrees all in and was rewarded with a 10.03 and 135 mph and change,  after the second attempt on my 29.5/10.5 tires Friday night. Pulled plugs and everything looked fine and dandy, engine didn’t miss a beat. After some hard negotiating with myself back and forth Saturday morning I decided to pull 3 degrees more timing and bump the plate up to a 82 jet and put the 32/14 big tires on and let her roll the dice and see what shakes out. Finish line rpm was 7100 roughly Friday nite and I though I could do the old engine a favor and get the finish line rpm down a touch since it’s waaay overdue for a refresh. So quick 8 qualifying pass with no Transbrake again and grab the button as soon as I could I was rewarded with a 9.90 and just short of 137 mph. Kinda goofy running down a thunderbolt clone in a 4200 lb hillbilly pickup.. he went 9.84 and tree’d me a little bit but I had almost 2 mph on the car with my truck on the big end lol… wonder what he was thinking when he seen me right next to him, I didn’t get his name but it’s a beautiful burgundy t-bolt car, I assume a clone. I made one N/A pass and it went 10.93 and 122 mph but that was with the timing still pulled out. Pretty pleased with the truck’s performance, driver was suspect though, couldn’t get a green light to save my butt… last three attempts were .023,.024,.024 red… got to put names to some new faces and converse with a few old friends from ford race years gone by so it was a successful ish weekend ::)
Now to get the Booggy box installed and the Transbrake fixed to see what the truck can really do, then probably install some more bars in the cab since I surpassed the 10.00 mark without it being a perfect pass scenario. Anyway, me and the truck are still around, fun event, good people, nice venue, and plenty fast fords, just would love to see more FE’s…. Now back to reality (work)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
Great job with the truck Cody, glad to see you are still thrashing on it.  The 9 second pickup!  Not bad...
6667fan
  • Every Second Counts
That is hauling, nice. Plus not exactly the picture of a slipstream machine.
Did Jay’s Victor make it on there?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
