Author Topic: Shortest deck height on a factory block FE?  (Read 5382 times)
« on: April 24, 2017, 06:01:19 AM »
What's the shortest deck height anyone has run with no issues on a factory block FE?
I understand intake manifold fitment has to be dealt with.  I'm more curious about the structural integrity of the block, retaining head gaskets, etc.
I think 10.15" is not uncommon at all.
So the question is, how low can you go?
thanks,
paulie
Re: Shortest deck height on a factory block FE?
« Reply #1 on: April 24, 2017, 06:34:58 AM »
I have went 10.135" a couple of times.
XR7
« Reply #2 on: April 24, 2017, 10:23:44 AM »
Hi Paulie, on my old beat up center oiler, it must be about 10.132 as the pistons (normal stroker deal) that I ordered for a zero deck at 10.150 are .018 out of the hole! I used a Cometic 5 layer head gasket at .060 thick and all is well, no issues at all. I have re-used those gasket twice now and will re-use them again when I put my high riser heads on soon. Those gaskets are expensive... but I had no other choice.
57 lima bean
« Reply #3 on: April 24, 2017, 11:16:27 AM »
"I have re-used those gasket twice now and will re-use them again when I put my high riser heads on soon"...anything special to know when cleaning these gaskets?
gt350hr
« Reply #4 on: April 24, 2017, 11:34:16 AM »
   10.130 is the shortest I have seen.
« Reply #5 on: April 24, 2017, 05:13:19 PM »
Thanks guys!
That gives me a ball park figure, and a sanity check.  My next combo will require custom pistons in any case, so I was just wondering how much I could reasonably move things around.
paulie
edgarval
« Reply #6 on: May 17, 2017, 09:00:12 PM »
Is 10.3 even shorter ?
gt350hr
« Reply #7 on: May 18, 2017, 09:30:39 AM »
    No 10.3 is taller and the same as the 429-460 , 351M-400.
