Author Topic: lost a little oil pressure  (Read 3132 times)
« on: April 19, 2017, 07:29:40 PM »
i just replaced my stock cj heads,pi intake,and stock adj rockers with bbm heads rpm intake and hs rockers.i fired it up after the swap and it sounds wonderful but i used to have 75 psi at startup,but it now has 60-65 at startup.i had restrictors to the rockers on the cj heads,but the bbms i did not touch them.any reason on the oil pressure loss,or is it nothing to worry about?
Re: lost a little oil pressure
« Reply #1 on: April 20, 2017, 07:19:49 AM »
What's your pressure at idle, warm? They're probably just flowing more oil to the rockers, and as long as the head isn't flooding and you have decent pressure at idle, I wouldn't be concerned.
