Author Topic: It don't fit?  (Read 8607 times)
james
It don't fit?
« on: April 11, 2017, 04:57:24 PM »
I just found out today when my car restorer was doing a mockup that my c-6 transmission does not match (the bolt holes) with my 427 fe motor. I also cannot remember the year of my block? I think it might be a 64 block so I included a pic of some numbers. Any advice would be greatly appreciated. Thanks!
rhinosoft
Re: It don't fit?
« Reply #1 on: April 11, 2017, 05:06:25 PM »
Transmission is for different engine type, could be for the 429/460 engine - oops.
Here is one of the first links that might assist.
https://www.cartechbooks.com/techtips/fordc4c6transmissions/
Graeme
57 lima bean
Re: It don't fit?
« Reply #2 on: April 11, 2017, 05:09:10 PM »
You will need a round bell case for your FE.That looks as if it for a 385 series engine.
wayne
Re: It don't fit?
« Reply #3 on: April 11, 2017, 05:32:27 PM »
Thats a small block c6
james
Re: It don't fit?
« Reply #4 on: April 11, 2017, 10:39:27 PM »
Thankyou guys, I already got a line on where I can the right c6 for the car. I do have a second question? Who sells or makes a steering column with the u joint instalation kit to fit on a mustang two rack and pinion? Thanks again.
gt350hr
Re: It don't fit?
« Reply #5 on: April 12, 2017, 10:28:53 AM »
   +1  small block trans
Re: It don't fit?
« Reply #6 on: April 12, 2017, 12:27:11 PM »
In regard to steering, check with Ididit. 517 424 0577. Quality stuff.
james
Re: It don't fit?
« Reply #7 on: April 12, 2017, 06:18:40 PM »
Another question? Would it be alright to use shorty headers on this 1966 mercury comet 427 fe motor with a c6 transmission? Shock towers are already cut with a mustang 2 front end suspension? And who sells them for this application? Thanks!
james
Re: It don't fit?
« Reply #8 on: April 24, 2017, 05:48:42 PM »
Ok I'm back with the same original problem regarding a c6 transmission. I said I found one but it is not the right one. I need a core or even the bellhousing like the following picture. Any help will be appreciated. Thanks!
« Last Edit: April 24, 2017, 05:50:38 PM by james »
Re: It don't fit?
« Reply #9 on: April 24, 2017, 06:02:58 PM »
That picture is of a 429-460 trans
Re: It don't fit?
« Reply #10 on: April 25, 2017, 08:30:15 AM »
X2 - that C6 will fit a 351M, 400, 385 Series (429-460).  Not FE.
james
Re: It don't fit?
« Reply #11 on: April 25, 2017, 06:38:19 PM »
Listen falcon67, I really appreciate you posting the diagrams of the various C6's. I tried to find them myself but had no luck. I did find what I wanted yesterday and it will be delivered to my tranny guy in the next few days. Here's a pic and it's out of a 1966 thuderbird that had a 428 in her. I also included a pic of my 1964 Falcon sprint to a fellow Falcon owner. Thanks for your help as well as to the others.
FElony
Re: It don't fit?
« Reply #12 on: April 26, 2017, 12:59:54 PM »
If that trans is original to the car it's going to have a green dot valve body, which is '66 only. You need to source a '67-up VB; I'm pretty sure the one in the SB trans you already have will work. However, that orphans the rest of the SB trans, which somebody with a 351 might want.
Fun, huh? Get the FE trans apart and throw out some casting numbers from the case and the VB, and take it from there.
babybolt
Re: It don't fit?
« Reply #13 on: April 26, 2017, 01:59:12 PM »
Also the 66's don't have the oiling hole in the back which needs to be drilled in the case from the bottom.  Adding this as an edit - also the 66 (and maybe the 67's) won't take an R servo.
« Last Edit: April 26, 2017, 06:01:44 PM by babybolt »
Re: It don't fit?
« Reply #14 on: April 26, 2017, 02:37:47 PM »
Very nice car - thanks for sharing that.  Glad you were finally able to find what you needed.
