Author Topic: Edelbrock 6005 Heads -SOLD  (Read 13009 times)
« on: April 09, 2017, 10:04:18 PM »
Up for sale is a set of used Edelbrock 6005s. These have a few hundred street miles on them. I have not run them, but purchased them from a friend who took them off a running motor. When I got the heads, they had a decent set of springs/retainers/keepers that matched my cam better that was in my car at the time, so I swapped out my old ones for the ones on these heads. The current springs on these heads I would NOT run. I put them on to make them complete. They checked at around 80-90 on the seat and about 215-225 open at .560" lift. The drainbacks I enlarged to 1/2" and radiused, but did not touch the intake side yet. The oil feed slot has been radiused at the edge leading into the head bolt hole on each. No porting on intake or exhaust. Minor pitting at a couple coolant ports on intake side. Should seal fine w/small dab of rtv.
Price is $975 free shipping within US
« Last Edit: May 09, 2017, 06:54:08 PM by Nightmist66 »
jholmes217
Re: Edelbrock 6005 Heads
« Reply #1 on: April 13, 2017, 04:37:48 PM »
I sent you an e-mail on these by clicking on your profile.
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
« Reply #2 on: April 13, 2017, 10:21:03 PM »
I'm sorry, but I haven't seen an email yet. I will send you a PM.
Thanks, Jared
« Reply #3 on: April 14, 2017, 05:45:59 PM »
Still for sale.
« Reply #4 on: April 28, 2017, 05:35:36 PM »
$975 and free shipping within US
FERoadster
« Reply #5 on: April 28, 2017, 08:02:07 PM »
What are the valve sizes?
bluef100fe
« Reply #6 on: April 28, 2017, 09:53:18 PM »
Are they the original 2.09/1.65 valves? Do you know the actual chamber size? Thanks
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #7 on: April 28, 2017, 10:58:27 PM »
Factory installed CJ size.
« Reply #8 on: April 28, 2017, 11:01:27 PM »
Supposed to be 72cc. I have not actually cc'd any chambers yet. Can if you would like. As far as I can tell, heads were never milled.
bluef100fe
« Reply #9 on: April 29, 2017, 05:37:40 AM »
Jared,
If you could pour one chamber that would be great, last set of 6005 edel's I had my hands one were closer to 80 cc's before I milled them a bunch.  Also where are you located in IL ? I'm going to be down there working next weekend, possibly save time/money on shipping if we can meet up? Also I can't use the used springs or retainers, waaay to light on psi for my junk,  and I'd prefer to buy just the valves and heads if possible? That way I could also verify the valve guide and seat condition... let me know, thanks
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #10 on: April 29, 2017, 08:58:38 AM »
Cody, I will try to get a chamber measured for you. I am located in northern IL, about 2 1/2hrs west of Chicago. I can take the springs/retainers off if need be. I will PM you some more contact info. Thank you.
« Reply #11 on: April 29, 2017, 06:17:11 PM »
I CC'd the end chambers on both heads. One head was 73.5cc's on both ends. The other came out 73.5cc and 74cc. I used an NGK BKR5E plug for checking.
« Reply #12 on: May 01, 2017, 12:22:31 PM »
Sale pending...
fastback 427
« Reply #13 on: May 01, 2017, 01:19:45 PM »
If cody changes his mind , i would like to be next in line.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #14 on: May 01, 2017, 03:11:46 PM »
Hi Jaime. Someone PM'd me after Cody inquired. You are third in line.
Thank you, Jared
