Author Topic: Billet Intake Manifold for the Tunnel Port Intake Adapter  (Read 42262 times)
Re: Billet Intake Manifold for the Tunnel Port Intake Adapter
« Reply #30 on: March 22, 2017, 10:41:45 AM »
Awesome stuff!!! I was thinking the adapter with a 351C fox body style fuel injection intake would be cool, but this is even better.
Makes this setup that we have kind of obsolete.....
« Reply #31 on: March 22, 2017, 11:39:03 AM »
Jay, can you dimension this? Wondering if it would fit under an F100 hood without surgery. Just trying to get a rough figure of the size in general.
« Reply #32 on: March 22, 2017, 02:46:50 PM »
I'll bet it would fit, Mike.  I measure 12.75" from the top of the block rail to the top of the forward facing Holley EFI top.    If you want to run carbs, I measure 11.25" from the top of the block rail to the carb mounting surface on the carb plenum.  Hope that helps - Jay
ericwevans
« Reply #33 on: March 22, 2017, 03:13:24 PM »
Depending on the vintage, you can get quite a bit under the hood of an f-100.  My '65 is running a 1" carb spacer and a 3" air cleaner with a flat base on a run of the mill iron 4V low riser manifold and there is at least 1 1/2" inches still left above it, what Jay has pictured looks shorter than my setup as the base of my air cleaner is just above the distributor cap.  I think the hood got lower in '67 so there would be less room on later trucks.
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
« Reply #34 on: March 22, 2017, 03:57:14 PM »
If only someone made a set of tunnelport aluminum heads with efficient combustion chambers.............
« Reply #35 on: March 22, 2017, 07:46:44 PM »
FYI for anyone interested, I tried to fit the MSD distributor with the shorter cap today, and still no luck.  Looks like the stock Ford distributor is the only way to go with this setup.
« Reply #36 on: August 26, 2017, 01:58:52 PM »
It's been quite a while but I am finally getting close to finishing up this project.  Just as a refresher, here is a picture of the 3D printed billet intake, that some of you may have seen at the FE Reunion in April:
More pictures of the 3D printed manifold are shown earlier in the thread.  Most of the plastic is now in aluminum.  Here's a photo of the runners, equipped with O-rings on both ends to seal to the intake adapter, and then to the plenum:
When they come off the CNC machine they are kind of a dull silver in color, and I wanted to see what they would look like polished up, so despite the fact that I am really not set up to polish aluminum, I took a stab at it to get the general idea.  They actually polish very nicely, which I guess makes sense since they are billet aluminum.  Next I bolted them onto the intake adapter; here's a few more pictures:
Once I had the runners machined I started on the plenum, which was a much more complicated prospect.  However, over the last week I've made some pretty good progress, and am almost finished up with the inside surfaces; see the photo below of the part, still on the CNC machine:
Once the plenum is done I just have to machine the brackets to hold the fuel rails, and the project will be complete.  As mentioned earlier in the thread this intake will be used with a Vortech supercharger blowing into one of those Holley LS front facing tops.  As it happens I have another tunnel port customer who wants the same basic setup, but instead of a Holley top he will be mounting a 6-71 blower on top of the plenum!  That should be a really cool setup; I have the runners done for that one as well, and will start on the plenum when I have this one completed.  I will post some pictures of that setup too when its done.
« Reply #37 on: August 26, 2017, 02:23:49 PM »
Jay, that is soooooo sexy! You've started an FE porn site!   :) ;) :D ;D
« Reply #38 on: August 26, 2017, 08:38:55 PM »
Wow.
That roots engine will be riding high. I'd love to see what that one is going into! Can't wait to see either of them done, actually! Very nice, Jay!
preaction
« Reply #39 on: August 26, 2017, 10:36:52 PM »
Jay are you familiar with CPVC plastic ?
« Reply #40 on: August 27, 2017, 09:08:25 AM »
Nope.  ???
Mistral_427TP
« Reply #41 on: August 27, 2017, 06:37:34 PM »
Wish your product was available few years ago; would have been much cleaner and easier.
Here's mine; finished Oct 2014
BTW link was from PB
-Johnex Cobra Replicar
preaction
« Reply #42 on: August 27, 2017, 07:23:35 PM »
Nope.  ???
its PVC with a very high heat resistance.
« Reply #43 on: August 27, 2017, 07:36:16 PM »
Why did you mention it?
preaction
« Reply #44 on: August 27, 2017, 08:16:35 PM »
From your posts of the issues you were having with the ABS then the PLA plastics warping and questions of heat survivability, did I miss your getting a better plastic ?
