Author Topic: Random SBF/FE parts for sale....  (Read 4681 times)
« on: March 13, 2017, 11:00:05 AM »
*New Eagle cast Ford 302 crankshaft, 3" stroke, 2.123" rod journal. $150
*Ford 1970 351W heads, complete. $100
*68 Ford 302 4V intake - $50
*1968 Mexican 302 block. Has had a couple inches of Hard Blok poured in it (well below water pump holes) to stabilize the cylinders. Has been align honed with ARP main studs. Will need bored/honed/decked to spec. I will sell as is, or finish it for you. $500 as is.
*Ford 390 block, fully machined. Caveat to this one...
This is the block that was in this thread:
http://www.network54.com/Forum/74182/message/1489083886/Jay%27s+transparent+valve+covers+and+an+internal+water+leak+fiasco....%28LONG%29
It's a 4.080" bore, fresh hone with a BHJ fixture, square decked to 10.150" with BHJ, and align honed with ARP main bolts. There were two cracks found inside the block when it was pressure tested to 30 psi. They have been repaired by Ray Shepherd (Ray's Crack Repair). Block has passed pressure testing and is ready to assemble. Since it has been washed several times since disassembly, it will need to be repainted. It currently has brass freeze plugs.
I'm asking $750 for this block. Will arrange shipping if necessary, or you can pick it up.
