Author Topic: run it first or change it first (oil)  (Read 6440 times)
rcodecj
« on: May 16, 2012, 07:07:56 PM »
Car sat 2 years. Oil has very few miles on it but doesn't look super clean any more. Question is:
1) Change oil, pre lube engine, start it
2) pre lube engine, run it until engine is up to temp, change oil
Re: run it first or change it first (oil)
« Reply #1 on: May 16, 2012, 07:24:14 PM »
#2!
« Reply #2 on: May 16, 2012, 10:24:21 PM »
I would also say go with option 2.
« Reply #3 on: May 17, 2012, 05:05:24 AM »
#2
Hemi Joel
« Reply #4 on: May 17, 2012, 10:36:14 AM »
I think oil changes based on the age of the oil are over-rated. If it only has a few miles on it, and it is not contaminated by water or gas, I don't care how old it is, i'd run it till it had a suitable amount of miles on it.
« Reply #5 on: May 18, 2012, 08:48:38 AM »
Is this your engine?  if so and you know the history, I'm with joel.... Just run it.
If you are buying an engine from someone, you never know how sludgy it is.  I change the filter, run it a few hundred miles and than change oil and filter.
Whats an oil filter cost $40?
