Author Topic: 8 bolt vs 16 bolt exhaust Edelbrock head differences?  (Read 5881 times)
jholmes217
« on: February 10, 2017, 05:16:03 PM »
Besides 18 bolt vs 8 bolt on the exhaust, are there any differences between what the call the 427 head vs what they call the 390/428 head?
« Last Edit: February 10, 2017, 05:18:59 PM by jholmes217 »
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
wsu0702
Re: 8 bolt vs 16 bolt exhaust Edelbrock head differences?
« Reply #1 on: February 10, 2017, 06:15:42 PM »
The only other difference is the combustion chamber.  The 427 heads have machined 76cc chambers and the 390/428 heads have a cast 72cc chamber.  Both have ports that are based on Ford C5AE-F Medium Riser head design and CJ size valves (2.09/1.66).
« Last Edit: February 11, 2017, 12:55:33 AM by wsu0702 »
jholmes217
« Reply #2 on: February 10, 2017, 09:05:04 PM »
The only other difference is the combustion chamber design.  The 427 heads have machined 76cc chambers and the 390/428 heads have a cast 72cc chamber.  Both have ports that are based on Ford C5AE-F Medium Riser head design and CJ size valves (2.09/1.66).
So would the 8 bolt work OK as a direct swap for 428 Cobra Jet heads on a 428?  Current compression ratio is 10 to 1 (machine shop dished the pistons a little) with the iron heads.
Jeff
Olympia WA. area
wsu0702
« Reply #3 on: February 10, 2017, 09:53:33 PM »
Have your stock CJ heads been milled?
« Last Edit: February 10, 2017, 10:13:52 PM by wsu0702 »
jholmes217
« Reply #4 on: February 10, 2017, 10:33:09 PM »
Unknown.  I'm running 92 octane pump gas in it no problem.
Jeff
Olympia WA. area
427Fastback
« Reply #5 on: February 10, 2017, 10:52:16 PM »
I bought the 8 bolt 427 heads because they say the seats can be cut for the 427 size valves.I then redrilled /heli coiled them for the 16 bolt pattern.Now...I have never seen the two sets side by side so I don't know if they have different seats.
I also CC'd my heads and they were bang on..I have heard the 72CC heads are actually in the 76-78 CC range.I did lose half a point on my compression but its a street car and I doubt I will notice with all the other changes I made..
1936 Diamond T 212BD
1990 Grizzly pick-up
wsu0702
« Reply #6 on: February 11, 2017, 08:44:07 PM »
Should be about the same compression ratio.  Ford lists the stock CJ head chamber as 72-76cc but a lot of guys have measured untouched stock heads and they report chamber volumes in the upper 70s.
