Author Topic: C8AE-H Heads, Three Speed Toploader and Other Parts  (Read 4132 times)
hyper64
« on: February 06, 2017, 02:41:21 PM »
One set of C8AE-H heads, dates: 9C24,9K23. This pair was done quite awhile back used for a short time then stored. I have the receipt for the work which included a valve job, surface heads, install bronze wall guides, new seals and shims, springs also look new. $400.00 SOLD
 1965 Ford three speed Toploader transmission and parts. This transmission was taken from my 1964 P-code cop car. The tag is HEH-K which decodes for a 1965 Galaxie 390. The transmission is in nice condition and usable as is. Also included is the C3AA-6394-A bellhouse, a 153 tooth flywheel, a modern starter, a new starter drive(from John V.) that works with the early flywheel,starter, fork, throwout bearing, and associated parts(attaching hardware). $400.00 for the whole thing. SOLD
 Mustang T-10 transmission with Hurst shifter and linkage, needs a rebuild, was on a 1967 S code Mustang $450.00
 C4AE-B crankshaft $200.00 SOLD
 Thunderbird script valve covers restored painted gold. $200.00
 Ford pentroof valve covers restored painted gold, Mr. Gasket pn 275 gaskets installed. $225.00
 Mickey Thompson valve covers $150.00 SOLD
 Weiand cast aluminum valve covers restored slight blem on fin. $200.00
 1966-69 outer equalizer bar (z-bar half) NOS $125.00 SOLD
Balancers both are C4AE 6316-A with crank bolt $75.00 each
OEM Ford dual point distributor: COAF 1212-K 1961-63 390 Ford Special 4V, 1961-63 406 Ford Special 4Vand 6V $250.00
Edelbrock Performer intake, Edelbrock Performer Series 1406 Carburetor, Edelbrock air filter assembly, throttle rod. Bolt on induction for mid level cruiser $500.00
MAD Enterprises electronic type conversion kit for FE. $70.00
Rubber alternator boot came off a 1964 P-code cop car no visible part number nice condition. $65.00
FE Ford truck exhaust manifolds, came off a 1974 F-250 Super Camper Special with a 390: C8AE9431-A and B $100.00
1966-67 Fairlane 427 dog dish hubcaps good driver quality. $175.00
FE Expansion Tanks $45.00 each
 Shipping is not included in the stated prices.
 Pictures available upon request. I am located in Southeastern CT.
Thanks for the space Jay.
 8six0 70five1180
jamesamacione@gmail.com
« Last Edit: October 11, 2017, 06:20:09 AM by hyper64 »
Philws
Re: C8AE-H Heads, Three Speed Toploader and Other Parts
« Reply #1 on: October 10, 2017, 04:51:50 PM »
Still got the heads?will they fit a 390
Phil
philws00@yahoo.com
