FE Technical Forum
Water pump adaptors
Topic: Water pump adaptors (Read 3787 times)
Leny Mason
Sr. Member
Water pump adaptors
February 04, 2017, 09:44:33 AM »
With the water pump adapters on a Cammer can I use the stub cam to run my distributor or is it in the way. thanks Leny Mason
Administrator
Re: Water pump adaptors
Reply #1 on:
February 04, 2017, 11:10:21 AM »
The water pump is in the way, Leny. If you want to drive the distributor off the stub can you will need a remote water pump. Meziere makes a good one.
Leny Mason
Sr. Member
Reply #2 on:
February 04, 2017, 04:22:57 PM »
Thanks I will see if I can find it. Leny Mason
FE Technical Forum
Water pump adaptors
