Author Topic: what edelbrock heads to buy? confused!  (Read 6105 times)
fallguy72
« on: January 31, 2017, 10:03:03 AM »
want to buy heads for my 445 currently running c6ae-u heads that bolt up to my fpa headers. i have a 280h comp cam and rpm intake the part #s are confusing and pictures are all the same on edelbrocks site. what power gains should i  expect? can i run the same stock rockers? what part # should i get!
Re: what edelbrock heads to buy? confused!
« Reply #1 on: January 31, 2017, 06:28:35 PM »
The best Edelbrock heads to buy are BBM or Survival.  :P
« Reply #2 on: January 31, 2017, 07:12:45 PM »
These are the Edelbrock heads that would work best with your combination:
https://www.summitracing.com/parts/edl-60065/overview/make/ford
I'm not sure if your headers will bolt right up and match up to the port, but you can slot the bolt holes to make them work if they aren't right.  You can run the same rockers.  Hard to say how much power you will pick up, but you will definitely see an increase.
fallguy72
« Reply #3 on: February 02, 2017, 08:13:52 AM »
Thanks for the reply Jay Brown i am ordering the 60065 heads today $1070 per head cdn plus tax gaskets and other things i need. i know arp bolts would be best but can i just use new stock replacement bolts? Lodrco said arp are expensive and this is already 1 months wages.
 https://www.youtube.com/watch?v=e1ubzO6kZtU
« Last Edit: February 02, 2017, 08:15:52 AM by fallguy72 »
« Reply #4 on: February 02, 2017, 08:20:50 AM »
Is the exchange rate that bad?  Wow!
newfalconowner
« Reply #5 on: February 02, 2017, 01:30:55 PM »
the exchange is terrible.
« Reply #6 on: February 02, 2017, 03:24:29 PM »
Try to order them to Sweden....then you have terrible
exchange
« Reply #7 on: February 02, 2017, 09:03:53 PM »
You can use stock replacement head bolts.
