Author Topic: 1960 430 MEL Sonic Sheet  (Read 4538 times)
chris401
« on: January 25, 2017, 12:24:24 AM »
Out of two I've seen so far this is the thickest. Not the super thick cores I have heard about. I am in the process of making a pressure test kit for FE and MEL engines. Going to spray UV dye in the saddles, cam tunnel and lifter valley. Any known crack prone areas in these MEL engines I should look?
Next up is my 59 575XXXX casting block. Like this 60 it will take some work to get the pistons out. Maybe this spring I will pick up a complete 59 Conental. Depending on production date it may have a 575XXXX block casting as well. More to come.....
« Last Edit: January 25, 2017, 12:26:05 AM by chris401 »
Royce
Re: 1960 430 MEL Sonic Sheet
« Reply #1 on: February 01, 2017, 06:50:30 PM »
Chris  that is kind of disappointing..  I had a 58 383 block that was better than that after a .050 bore job
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
chris401
« Reply #2 on: February 01, 2017, 07:46:09 PM »
I have a complete 63 4 barrel 430 I will squeeze in a sonic test sometime. C3VE casting. Was your 383 a 575XXXX block casting?
Royce
« Reply #3 on: February 02, 2017, 09:21:08 AM »
Chris.. Have you tore down that 63 yet?  I would like to get a picture of the heads. Do they have a small chamber?
1992 BMW V-12 5.0
chris401
« Reply #4 on: February 02, 2017, 03:44:17 PM »
Pictured is a C3VE-B head. 2 5/8" X 1 5/16" intake ports. I have not cc'd the heads yet but there is a chamber. The chambers were 63-65. I have not seen the 61-62 heads yet.
chris401
« Reply #5 on: February 02, 2017, 07:33:45 PM »
58-60 and 66-68 were flat with no chamber. 61-62?
These are 59 heads.
