Author Topic: Dependable Electric Fuel Pump?  (Read 4139 times)
chris401
« on: January 22, 2017, 12:54:10 PM »
Going to set one up with a return line regulated to a constant 7 1/2 psi needle pressure. Although I have looked at a few, I would like to know what is the group says is the most dependable. I want to make a 20 hour round trip and last for years like my mechanical has. Looking at long term daily driver over initial cost.
Thanks
Re: Dependable Electric Fuel Pump?
« Reply #1 on: January 22, 2017, 01:22:45 PM »
I like the Carter electrics for street ..... used the street pump 72 gph 4-6 internally regulated for close to 20 years before it finally failed .... replaced it with the Carter  7 psi 100 gph 5 years ago ..... very quiet and very reliable for mine stuff
chris401
« Reply #2 on: January 22, 2017, 01:36:30 PM »
Glad a spread bore guy responded but all are appreciated. It will be feeding a Quadrajet using 650 to 680 cfm at wide open throttle. Do you think 100 gpm 7 psi would keep the bowl full on a Quadrajet or Thermoquad?
Does the Carter ever drop to 5 1/2?
57 lima bean
« Reply #4 on: January 24, 2017, 08:14:05 AM »
Running the carter HP4600.  Love it.
Now that my car has 2x4 carbs with side floats, I added a regulator to keep the fuel at 4.5-5psi, works great.
Many many miles and 2 years or so, no issues.
chris401
« Reply #5 on: January 24, 2017, 09:10:45 AM »
Thanks
