Author Topic: Spirited 390 For Sale  (Read 5892 times)
CaptCobrajet
« on: January 20, 2017, 10:04:11 AM »
Spirited 390 FOR SALE:
High Quality throughout.  Bored, torque plate honed correctly, align honed, studs #2 and #4.  Ford iron crank, C7AE-B rods mag'd shot peened, polished, ARP bolts.  CP flat top pistons.  Hydraulic Roller .580 lift, 232/238@.050, 112 separation. Morel lifters.  Non-adjustable OEM rockers on heavy wall shafts with studs. Smith Brothers pushrods.  BBM heads with my Ferrea valves, 7-angle valve job, hand port upgrade, beehive springs.  Engine is 10.5:1 compression ratio.  Ed RPM manifold with plenum mods and port rework for the BBM head.  Holley 830 annular double pumper tuned on the dyno.  531 peak power, 508 peak torque. This is a very solid streetable engine with a "lumpy"  idle, but would drive anywhere on pump 93 octane.  It will work with power brakes.  I would recommend a slightly looser than stock converter or a straight shift trans.  The dyno info is posted in the Dyno Section here on Jay's forum.  $11,500.  Pics are available.  Inquire by email at captcj at hughes dot net.  Thanks.
« Last Edit: January 20, 2017, 10:07:10 AM by CaptCobrajet »
Blair Patrick
CaptCobrajet
Re: Spirited 390 For Sale
« Reply #1 on: February 05, 2017, 08:26:02 PM »
Price reduced to $10K if bought in February.  I just bought  a dyno and need to sell this engine. Thanks!
Blair Patrick
CaptCobrajet
« Reply #2 on: February 08, 2017, 11:06:55 PM »
390 is sold!
Blair Patrick
