FE Technical Forum
TKO short shaft or adapter?
Topic: TKO short shaft or adapter? (Read 5537 times)
ewo357
Jr. Member
January 15, 2017, 08:17:38 PM »
I'm putting a TKO behind my 445 in my 66 Country Squire with stock z-bar type linkage but it has the trans has the long shaft....
What are the pros and cons of having my shaft cut down??
What are the pros and cons of using an adapter to fill the gap??
Will I need a mid position shifter or will the rear shifter work?
Thanks in advance!
Cyclone03
Sr. Member
Re: TKO short shaft or adapter?
Reply #1 on:
January 15, 2017, 09:55:38 PM »
I had the shaft on my first TREMEC ground shorter,the shaft is hard like a crank shaft.
My current TKO is long with the matching bell housing.
I would use the adapter because IF you found yourself far from home you can have a trans shipped from Summit or Jegs if you had to have it. The short shaft may take longer.
With driver hot rods I try to use stuff that fits Mustangs and gasp,Chevies,less to no waiting if your out there.
Lance H
ericwevans
Full Member
Reply #2 on:
January 15, 2017, 10:18:14 PM »
I use the adapter and rear position on my 65 F100, it is really a too far rear IMHO.
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
ewo357
Jr. Member
Reply #3 on:
January 15, 2017, 11:18:25 PM »
The price is pretty much the same but I want to know if the clutch linkage lines up better one way or the other? I know I will need to cut my floor to fit the TKO but will the short shaft and no adapter make for less of a trans hump rise???
ericwevans
Full Member
Reply #4 on:
January 16, 2017, 02:31:35 AM »
My adapter plate goes between the bell housing and the trans, so the clutch linkage would be identical to stock. I imagine any transmission tunnel interference would be worse with the adapter but I cannot directly speak to that.
Eric Evans
Reply #5 on:
January 16, 2017, 05:14:44 AM »
I sell the input shafts ready to go. Takes 10 min to swap one out. Remember, the bearing retainer has to be modified too.
If you run a spacer, you have to worry about manufacturing tolerances for your bell, the spacer, and the trans.
Last Edit: January 16, 2017, 05:19:53 AM by blykins
YouTube: Lykins Motorsports
ewo357
Jr. Member
Reply #6 on:
January 20, 2017, 11:26:34 PM »
Brent, do you need my long shaft back as a core? Do you need measurements from me or is there only two lengths that it could be?
Reply #7 on:
January 21, 2017, 08:28:13 AM »
No core and there are only two lengths.
FE Technical Forum
