Author Topic: Which distributor????  (Read 3297 times)
Cobravii
« on: January 07, 2017, 09:35:45 PM »
I am buying a new distributor for my stroked 390. I see a few different choices out there but what I need the most guidance on is a strictly mechanical advance vs. mechanical and vacuum advance.
can someone tell me the desired distributor and why?
Thanks in advance,
ericwevans
Re: Which distributor????
« Reply #1 on: January 07, 2017, 10:16:34 PM »
If cruise fuel mileage means anything then get with vacuum advance.  I use a Pertronix on one engine and an MSD on the other.  The Pertronix will run without an ignition box and just drop right in, and can be had with a built in Rev limiter of desired.  On the MSD I use a 6AL box.  I like both distributors, the Pertronix is on my daily driver and runs well.
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
