Author Topic: Timing gear install  (Read 12339 times)
ChiefDanGeorge
Re: Timing gear install
« Reply #15 on: January 03, 2017, 08:52:11 AM »
Good deal, thanks!
The key for the balancer has to be short.
Push the spacer on and bottom it out against the timing gear, then just measure how much snout you have sticking out past the spacer and cut the key for that.  Should end up being around 3/4" or so.
ChiefDanGeorge
« Reply #16 on: January 03, 2017, 08:22:37 PM »
Filed the keys to fit and then took the dremel out and filed down the tops on both and now gear and spacer fit nicely.
