Author Topic: Quick Holley choke question  (Read 3980 times)
« on: December 29, 2016, 02:11:22 PM »
Hey guys I'm installing new out of the box Holley choke kit on a Holley 4778-6 4150.
The fast idle cam is not lining up well with the adjuster screw. Supplied spacers are way to much.
I figure a washer on each post will get it done. Any problems to think about?
Re: Quick Holley choke question
« Reply #1 on: December 29, 2016, 02:12:53 PM »
Hmm like vacuum port.
Maybe bend the adjuster arm a bit?
« Reply #2 on: December 29, 2016, 02:24:16 PM »
Yes, bend the arm but be careful if the entire lever can't be removed for bending. That pot metal on Holleys isn't very strong.
« Reply #3 on: December 29, 2016, 03:10:04 PM »
Wow, that was easy.
It bends way to well IMHO.
But it worked fine.
Also Holley was kind enough not to include a vacuum port gasket so I made one by cutting an extra idle adjust cork gasket in half with a razor blade. Kind of a bitch to make sure it's in place but seems to work well.
