Author Topic: Boninfante billet clutch. SOLD  (Read 6604 times)
« on: December 29, 2016, 12:37:27 AM »
For sale
 New, never used. Includes 5135 centered iron disk for 1-3/8"x10 spline input shaft , counter weights, spacers, long and short spring (base pressure) adjusters, dial guage , all SFI spec tags and basic adjustment instructions for both base and centrifugal adjustment.  Base pressure is adjustable from 480lb (no turns) to 1680lb (8 full turns) . Flywheel is 184 tooth for big block ford's,  FE and 385 series.  This clutch will work in a 6-1/2" can if you use a hydraulic throwout bearing.  You will need a 7-1/2" or 8-1/8" can to use mechanical linkage,  (ie clutch fork). This is a top notch piece that would cost you $2,600.oo new with the weight kits and dial guage.
$2,000.oo
« Last Edit: February 08, 2019, 10:14:46 PM by fekbmax »
Re: Boninfante billet clutch
« Reply #1 on: January 06, 2017, 02:14:22 PM »
that thing is so beautiful it's almost a shame to cover it up with a Bell housing  ...... the very " top "  shelf clutch for sure and would look great in the dining room too :)
« Reply #2 on: January 06, 2017, 03:02:20 PM »
Well, what ya waiting for?  I bet you got room on your coffee table. LoL.   ;D
rowdy58ford
« Reply #3 on: January 08, 2017, 09:28:39 AM »
How deep of bell do you need for the clutch?
« Reply #4 on: January 08, 2017, 11:26:55 AM »
hey rowdy58'
i responded to your personal message back on Jan 3rd. if for some reason you didn't get it i can re send it or post the info here. let me know.
« Reply #5 on: April 04, 2017, 09:02:12 PM »
Price reduced.  $1700.oo
Or
Will trade for 1 Fe power timing cover and Fe power adjustable timing set combo along with a Fe power 13002 intake adapter and a pair of 13204 plates.
LoL, worth a shot. Maybe Jay is ready to build a clutch for his SOHC or other FE !!!
« Reply #6 on: April 04, 2017, 09:32:15 PM »
Or,
8.5 to 1 ish blower pistons at a 4.08 bore and a set of decent (Scat or RPM or..) H beam rods at 6.49 with ford Jornal 's .
Re: Boninfante billet clutch. SOLD
« Reply #7 on: February 08, 2019, 10:16:00 PM »
Sold..
