Author Topic: 4.30 stroke crank  (Read 5956 times)
bn69stang
4.30 stroke crank
« on: December 17, 2016, 09:05:22 AM »
I guess this question would be directed towards Blair , maybe Brent and Barry , who makes the 4.30 crank and whats the price range ? and any other info on this item .. Thanks Bud
Re: 4.30 stroke crank
« Reply #1 on: December 17, 2016, 10:04:11 AM »
RPM makes a 4.375".   You can get them for around $750-ish out of the box, but they will require a touch grind on the rods and mains before they will be usable.
CaptCobrajet
« Reply #2 on: December 17, 2016, 10:26:09 AM »
Brent is correct.  Not sure you could see much diff between a 4.250 and 4.300 in most situations.  Crower, Moldex, and Scat can all create billet 4.300s for a price much more than a steel 4.250.  You get what you pay for in strength and quality.  The question is,  what is the requirement?  The high end cranks can be needed, or can be overkill, depending on the use.
Blair Patrick
bn69stang
« Reply #3 on: December 17, 2016, 03:33:09 PM »
I remember you using them in a build or 2 , and was just wandering where the piston pin was in relation to the ring land on the piston ?
bn69stang
« Reply #4 on: December 18, 2016, 09:13:38 AM »
Thanks Blair and Brent for the feedback.. Bud
Randy
« Reply #5 on: December 28, 2016, 09:32:18 PM »
I have a 4.375 forged crank I bought new from Barry R and had it balanced ready to go, found out I made a mistake and it was supposed to be a 4.250  :-\ I am going to sell it if interested, you would need to balance it for your rods and pistons.
Randy
