Author Topic: F/S 1963 F-100 UNIBODY SHORT-  (Read 4875 times)
« on: April 30, 2012, 04:05:37 PM »
box pick-up truck. This is an (up-dated) rough approximation of the truck that 'Skinny' Fuche ran out of DST. It has MANY miles on it and came from W. Virginia thirty years ago, where it was obviously used for a work-truck. It has a Volare front suspension 'K'-member in it with disc brakes and an Omni R&P as well. It's set-up to take C6 (supplied) or Top-loader and had a 390 in it since the late '80s. Small rust but only patching necessary---no entire panel replacement. Needs floor fixed and associated cab mounts. This truck was running when I pulled it into the garage to do the front suspension. A couple of weekends of work and the installation of your FE engine and it'll be drivable again. Has many hot rod accoutrements. 4.11 9". $4K OBO Call for information or pictures
UPDATE---TRUCK AS IT SETS WITHOUT AFTERMARKET HOT-ROD STUFF---$1500---GOTTA GET IT OUT OF THE WAY---DICKER ON THE HOTROD STUFF.
Ken Sheffer
cammerfe@yahoo.com
734 772 4501
« Last Edit: July 02, 2012, 04:55:45 PM by cammerfe »
