Author Topic: Oil pumps  (Read 4044 times)
428 GALAXIE
Oil pumps
« on: November 04, 2016, 12:50:43 PM »
Just been wondering when do you need hv  or hp oil pump.This thing comes around and goes around every site but no real answer.
I have messed around 70-80 honda motorcycles and know them like in and out but these fe:s are new territory for me.
So what do you do and what is the reason for that.
Mikko
Mikko
Re: Oil pumps
« Reply #1 on: November 04, 2016, 01:02:22 PM »
I like high volume oil pumps in my engines.  You get a little extra pressure, but not an excessive amount, over a standard pump, plus there is extra oil available if an internal leak suddenly appears in the engine (cracked rocker arm shaft, broken rocker, lifter popped out of lifter bore, etc).  I always use restrictors to the rocker arm shafts when using a high volume pump, to avoid too much oil pooling in the valve cover area.  And I always run a minimum of six quarts of oil.  Works for me - Jay
428 GALAXIE
Re: Oil pumps
« Reply #2 on: November 04, 2016, 01:24:39 PM »
First thing after engine dissembly and analysis was was t-pan type mod to the original oil pan and minor splash shields.
And to make things clear i am  not entering next year engine masters to save couple hp from the pump to the pump,just trying figure minimum needed for me ;D.
mikko
« Last Edit: November 04, 2016, 02:02:12 PM by 428 GALAXIE »
Mikko
