Author Topic: How severe is this crack in a block?  (Read 5445 times)
drdano
« on: October 13, 2016, 10:20:27 AM »
There is a 427 center oiler I'm vaguely interested in.  It has a crack according to the seller between the rear water jacket hole and the DS rear upper head bolt hole.  Would a crack like this need to be repaired?  If so, can it be repaired?
Re: How severe is this crack in a block?
« Reply #1 on: October 13, 2016, 12:55:08 PM »
I would fix it and I don't think it would be a bad job to fix...
However, that block is RUSTY.  Be on the look out for bad pitting in the cylinders.  A sleeve or two won't hurt anything, but you don't want to get into a spot where every cylinder needs to be fixed some how.
« Reply #2 on: October 13, 2016, 02:01:25 PM »
Maybe clean that block really good and check for any other issues before dropping a lot of $ on it.
drdano
« Reply #3 on: October 13, 2016, 08:45:53 PM »
Thanks for the feedback guys, I'd never seen a crack at that location so I wasn't sure if it was a big deal or not.  I think I'll pass on it.  Decent price at $800, but could be a bag of worms rehabbing it back into useable shape.
« Reply #4 on: October 13, 2016, 09:10:57 PM »
Where is the block located?
Is there an add for it.
drdano
« Reply #6 on: October 13, 2016, 11:17:51 PM »
The crossbolt spacers appear to be missing.  That could be an expensive problem to fix  :o
