Author Topic: coil packs  (Read 4762 times)
Hemi Joel
coil packs
« on: October 03, 2016, 12:39:34 PM »
Jay, why not use coil packs that mount right on the spark plug for you cammer? Like the new cammers?
chris401
Re: coil packs
« Reply #1 on: October 03, 2016, 01:05:31 PM »
I thought of that also for OHV FE. Could lock the distributor and incorporate the engine module from a base model, all manual 5.4 2001 F-250. I have worked with younger techs who were big on assigning false values to run an engine in what ever car they wanted. One tech had a Cadillac 4.9 in his 5 speed Pontiac Fiero.
« Last Edit: October 03, 2016, 01:09:52 PM by chris401 »
Re: coil packs
« Reply #2 on: October 03, 2016, 01:11:47 PM »
Just a guess as to why Jay doesn't, but you'd have to make some special brackets to mount them to the valve cover. Besides that, who wants to dirty up such a beautiful engine with 8 ugly coils mounted all over it? ;D
And he's not using a distributor, except to run the oil pump. Fully programmable timing via a crank sensor.
chris401
Re: coil packs
« Reply #3 on: October 03, 2016, 01:25:05 PM »
Yes, brackets, wiring harness, injectors, ect. Figured they were a given. Like Doug though, when I think about how cluttered it would look I loose interest. They might appear more at home centered on a wide head like what we are used to seeing.
« Last Edit: October 03, 2016, 01:27:13 PM by chris401 »
Re: coil packs
« Reply #4 on: October 03, 2016, 01:39:00 PM »
Doug is right, I think that mounting coils on those beautiful valve covers would be nearly criminal!  Besides, I like the way the blue plug wires look, and with 8 coils there is more than enough time to charge and fire through the 1 foot long plug wires without any worry about a misfire due to ignition.
