Author Topic: M/R CJ rocker shaft bolt kit  (Read 5257 times)
« on: September 29, 2016, 08:52:04 PM »
Anyone making these ?  Not stud kits, bolt kits.
ericwevans
Re: M/R CJ rocker shaft bolt kit
« Reply #1 on: September 30, 2016, 11:53:34 AM »
I was recently looking for some to replace the hardware store bolts I found in my shafts  >:( and I could only find studs.
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
« Reply #2 on: September 30, 2016, 12:13:42 PM »
« Reply #3 on: September 30, 2016, 07:31:26 PM »
Keith, I've bought directly from ARP before but not sure if the price will differ.  Bruce
ericwevans
« Reply #4 on: October 02, 2016, 09:42:27 AM »
What do you guys do about the reduced shank bolt for the oiling?  I didn't see any in the list.
Eric Evans
« Reply #5 on: October 02, 2016, 11:15:35 AM »
That is why I've always used stock bolts or aftermarket studs; those have the reduced diameter shank.  I'm not away of any aftermarket bolts available like that.
« Reply #6 on: October 02, 2016, 12:57:25 PM »
id prob just turn a couple down a bit, not as much as stock, could be used as a type of rocker shaft oil restriction
« Reply #7 on: October 02, 2016, 05:09:14 PM »
Keith,
I'm curious, why exactly are you wanting to use bolts instead of studs?
« Reply #8 on: October 02, 2016, 06:13:46 PM »
Need something that's going to be temporarily permanent while setting up my rocker shafts and 9 Point mounting system. Need to be able to remove and install the bolts several times as I  leave shafts stands mounted to head and remove the bolts and slide the shafts in and out while still in place on head. Needs to be functional though so normal grade 8 hex won't work, haveta have the small head of the 12 point bolt like the 12 point nuts for the studs. Studs will be installed and used once everything is set up, tested and in race condition. Don't want to install and remove the studs over and over and gual them up.
