FE Technical Forum
Dove water pump
Topic: Dove water pump (Read 4375 times)
Russ67Scode
Full Member
Dove water pump
September 12, 2016, 02:40:18 PM »
So I have aluminum Dove water pump that needs a rebuild, who do you recommend to send it to ?
Thanks Russ
fastback 427
Sr. Member
Re: Dove water pump
Reply #1 on:
September 12, 2016, 02:50:39 PM »
Dove sells the replacement parts directly. Earl is usually there earlier in the day.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Russ67Scode
Full Member
Re: Dove water pump
Reply #2 on:
September 12, 2016, 02:56:53 PM »
Never pressed a water pump apart
It doesn't look too difficult
I will give him a call thanks
FE Technical Forum
Dove water pump
