Author Topic: Anyone have 427 Cross Bolt Spacers?  (Read 5936 times)
unclewill
« on: August 26, 2016, 09:02:32 AM »
My new (1968) SO block is missing several cross bolt spacers - does anyone have some laying around?  Anyone have a line on someone making them?  Any suggestions?  I know they come in three sizes, if someone can send me a handful, I'll send back the ones I don't use.
Thanks!
Re: Anyone have 427 Cross Bolt Spacers?
« Reply #1 on: August 26, 2016, 10:43:29 AM »
The chances of finding stock or used ones that will work correctly for your engine are very slim. They should be made specifically for YOUR engine. Any competent machine shop or engine shop should be able to make them. Also, there is a 'classifieds' section where this would probably be best suited.
« Reply #2 on: August 26, 2016, 11:49:33 AM »
I have two here from my last project. I believe we made these. They are marked .3732 and .3735. I'll give them to you if they'll be of any help.
unclewill
« Reply #3 on: August 31, 2016, 11:17:42 AM »
Email sent, did you get it?
« Reply #4 on: August 31, 2016, 03:40:58 PM »
No email yet. Try a PM here^.
Dave427SOHC
« Reply #5 on: September 07, 2016, 08:40:51 AM »
I have 2 complete sets if i remember corectly i will look I need a set of main caps for a sideoiler block so will be keeping a set for myself ill check in a few.They are easily made as said above.
« Last Edit: September 07, 2016, 04:00:30 PM by Dave427SOHC »
« Reply #6 on: September 08, 2016, 02:11:23 PM »
Do you still need the two I have? (I finally found my stapler toward making a package.)
