FE Technical Forum
3/8 line in/out fuel pump that is clocked to work with power steering on 63 Gal?
Topic: 3/8 line in/out fuel pump that is clocked to work with power steering on 63 Gal? (Read 3546 times)
63.5xl
Jr. Member
August 06, 2016, 08:40:35 PM »
I have a 3/8 not in and 3/8 not out fuel pump, but the connectors run right into my stock power steering pump on my 63 Galaxie, are there any you guys are running with power steering that will work?
The Real McCoy
Full Member
Re: 3/8 line in/out fuel pump that is clocked to work with power steering on 63 Gal?
Reply #1 on:
August 06, 2016, 09:36:19 PM »
I just went through this on my Galaxie a couple months ago on a Carter fuel pump I got from Survival. The bottom half of the pump can be rotated after taking all the screws out. The outlet on mine points to the road side rather than towards the PS pump bracket. I have the HP (427) style canister fuel filter. A slight rework of the pump to fuel filter canister line was required. It actually fit up quite well once that was done
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so." Mark Twain
FE Technical Forum
