Author Topic: Time serts  (Read 3932 times)
Time serts
« on: August 02, 2016, 01:17:14 PM »
Are the common carbon steel time serts what is commonly used it the aluminum heads when replacing the helicoils or is a better grade or different material serts being used ?
Re: Time serts
« Reply #1 on: August 02, 2016, 01:25:52 PM »
I like these better than time serts; I've broken a time sert or two.  Also you can get these with larger diameter external threads, to hold more force.  I've used the 5/8" OD ones before for 3/8-16 threads, like rocker shaft studs, to handle really big valve springs.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=757&PARTPG=INLMK32
Re: Time serts
« Reply #2 on: August 02, 2016, 02:01:36 PM »
Sweet !!.
Thanks Jay.
Should I use a standard tapered tap with those or a bottom tap ?
Maybe a tighter fit with the tapered tap ?
Re: Time serts
« Reply #3 on: August 02, 2016, 06:48:17 PM »
Sweet !!.
Thanks Jay.
I've always used a standard bottoming tap.  They come with some kind of a thread sealing or locking compound already applied - Jay
