Author Topic: Another new guy and a 445.  (Read 16426 times)
mn67
Re: Another new guy and a 445.
« Reply #15 on: July 26, 2016, 03:28:46 PM »
FElony
The car currently has a 57 9 inch with 3.50 gear, they are around 2 inches narrower than the original unit and sub frame connectors.  The future plans include cal-trac two hole drag setup and a mono leaf. The front end I am undecided. I am local to QA1 and will rely on them for shock recommendations. Probably one of their drive shafts as well. I have a C6 but am leaning towards a C4. Car is front disc rear drum and I am unsure what upgrades I will make to that. 3500 stall and the wheels will be 15” TQ Thrusts for tires you can squeeze a 275 60 in but it is tight and looks too big so something a bit smaller. Open to any suggestions. I will be doing a semi complete rebuild of the car as it has seen better days.
1971 Maverick Grabber
mn67
Re: Another new guy and a 445 heads are back....
« Reply #16 on: September 27, 2016, 09:04:58 AM »
Just got my heads back from the porter. No flow #'s yet but I think they look good. He did go a little further than I expected so I am assuming I will need to get the manifold ported next.
« Last Edit: September 27, 2016, 09:18:26 AM by mn67 »
mn67
« Reply #17 on: September 27, 2016, 11:46:38 AM »
Test fitted the water pump with Jay's adapters this morning. Very nice fit and finish on these pieces.
mn67
« Reply #18 on: January 03, 2017, 10:51:01 AM »
I know it needs some wire management. I was able to do a first start on the 445 over the weekend (video to follow). Fired right up after one carb spit.  Ran very well when being rev’d (1.5k to 2k or so). It did not want to idle, probably the lack of a choke and it being pretty cold out. I did warm it under a radiant heater in a warmish garage before priming and starting. It stalled when I attempted to idle it, and acted tight (starter would barely turn it over) when I attempted a restart. Arguably I did not put much effort into attempting a restart (core plug was leaking and I was out of time, not to mention the neighbors were wandering over) so it could be a ground, starter, battery, timing or something else. Since the whole need to work thing got in the way. I cut open the oil filter in our maintenance shop this morning out of curiosity. Not sure what they usually look like but it is pretty clean as was the oil nothing seems amiss. So I will replace the core plug get everything adjusted and try again next week. Sounds pretty good and was not making any unwanted noises so all in all I am pleased. I do need to get the leak fixed and get it dialed in a bit before it gets dyno'd. Got about 15 minutes run time. Other than the core plug (a compromised galley plug was addressed during priming) only other leak was a seeping fuel fitting.  So I will replace the core plug get everything adjusted and try again next week. I sourced virtually all my parts and advice from this forums members and owe a big thanks to all involved.
« Last Edit: January 06, 2017, 11:53:56 AM by mn67 »
« Reply #19 on: January 03, 2017, 11:49:14 AM »
Congrats on a successful start!
bn69stang
« Reply #20 on: January 03, 2017, 08:20:45 PM »
Looks and sounds like a great build , keep us posted what elevation are you at ? , you probably could get away with a 850 cfm carb on that set up , something to think about ..Bud
mn67
« Reply #21 on: January 03, 2017, 09:29:05 PM »
I am just south of Minneapolis so about 900 ft of elevation. I will see how it runs and maybe try an 850. I thought that might have been too much carb. Worth a try.
mn67
Re: Lets try that again.
« Reply #22 on: June 13, 2017, 03:18:17 PM »
Well lets try this again. I had a failure on the 445 and will be starting the same build again. With the exception of maybe a dual carb setup, provided I can find one. I can't think of much I am going to change. The one exception at this time is I am getting rid of the uni-lite, in favor of a Duraspark that Faron curved for this combo. Input is welcome as always.
chilly460
« Reply #23 on: June 13, 2017, 03:23:55 PM »
What failed?
mn67
« Reply #24 on: June 13, 2017, 03:43:44 PM »
Block failure in the #1 Cyl. Nothing else was hurt. I have another block that needs machining and then it just a switch of parts. I thought I would make any improvements that I may have overlooked the first time around if any while I am at it.
« Reply #25 on: June 13, 2017, 08:42:24 PM »
sounds like a plan to me.my first car was a 67 cougar,and if this is your first fe,get ready for a life long love affair!
