Author Topic: Fuel return line  (Read 4377 times)
tomsfe64
Fuel return line
« on: June 29, 2016, 09:33:57 AM »
I'm running a holly black fuel pump in my galaxie. The pump makes a lot of noise and i wondered if it's in need of a return line to the tank to relieve it of so much back pressure. Any  thoughts?
Yellow Truck
Re: Fuel return line
« Reply #1 on: June 29, 2016, 10:21:14 AM »
I'm running an Holley blue (only 110 gph compared to 140 for the black), and it makes an ungodly amount of noise. It has an internal relief valve set at 14 PSI, so it won't over pressurize or over heat.
As I understand it a return does nothing for the pump, but it can provide more consistent fuel pressure and cooler fuel.
Paul.
« Reply #2 on: June 29, 2016, 03:12:59 PM »
In order to use a return set-up, you must lay it out for that purpose. I don't believe the regular Holley pumps/regulators are designed with return in mind. Of course, anything's possible with a little ingenuity.
fastback 427
« Reply #3 on: June 29, 2016, 04:55:00 PM »
I've run the Holley red, blue and the black. All were very loud even with rubber mounts. Stepped up to the Holley hp 150 georotor pump and it is way way quieter. Well worth the extra $.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Yellow Truck
« Reply #4 on: June 29, 2016, 10:22:09 PM »
Agree the regulator needs to be specific for a return application, don't believe there is anything specific to the pumps. They put out 14 PSI and don't know or need to know if there is a return.
Paul.
