Author Topic: thermactor air pump used as a......  (Read 7669 times)
DEANs427
« on: April 07, 2012, 12:05:40 PM »
has anyone tried using a thermactor air pump (polution pump) in a cheap crankcase evacation system? ie. using the pump to suck on the crankcase rather than its designed purpose of blowing into the exhaust ports? just thinking...
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
Re: thermactor air pump used as a......
« Reply #1 on: April 07, 2012, 01:18:11 PM »
If I recall correctly GZ Motorsports builds their vacuum pumps starting with a Thermactor pump.  www.gzmotorsports.com
I've never tried using a stock pump but it might work...
« Reply #2 on: April 08, 2012, 09:16:56 AM »
When vac pumps started to become the rage some years ago I read an article about stock   Thermactor pumps. IIRC, they do work up to a point but a few racers said don't bother with an OEM unit. They didn't generate enough of a vacuum to do much and w/o a way to tighten the internal clearances one was left at the mercy of whatever clearances a specific pump had when installed.
Now, maybe those electric leaf blowers the ricer crowd claims can supercharge your engine might be a better bet.... ::)
DEANs427
« Reply #3 on: April 08, 2012, 02:51:51 PM »
yeah, a few years back I experimented with a power brake vacuum pump from a desiel school bus that I plumbed into the road draft tube on my 67. made about a tenth and 2-3 mph improvement if I remember. however the pump seized after a few passes and then I sold that car and did not pursue the idea anymore, until now...
1966 Fairlane
« Reply #4 on: April 08, 2012, 06:53:40 PM »
The trouble with the leaf blower approach is that it requires such a long extension cord!
« Reply #5 on: April 09, 2012, 07:59:11 AM »
The OE vacuum pumps work.  That's what they used for several years until the aftermarket ones became available.  There was a higher volume 460 application that was pretty popular.  Biggest problem was that they did not last long - they were intended to pump clean air and the soot & oil mist coming out of the crankcase was pretty hard on the internal parts.
rcodecj
« Reply #6 on: April 11, 2012, 05:28:06 PM »
X2 on the they don't last long used in that application.
