Author Topic: 1967 Fairlane XL  (Read 7567 times)
1967 Fairlane XL
« on: June 01, 2016, 05:58:10 PM »
I have owned this car for awhile. We used to take it on long road trips in the summer, do burnouts and the odd pass at the airport. It had my home built 390 and a wide ratio TL in it.
A couple of years ago I started to convert it to a drag stick car. So this about were it's at now.
We've made 14 runs with it now in this configuration.
Performance Summary:
      1/4 mile ET:11.93             1/4 mile MPH:112.61
      1/8 mile ET:               1/8 mile MPH:
      60 foot time:1.78
      Track: Greenfield Dragway
      Weather Conditions: Nice, pretty good head wind, it is an airport runway.
Vehicle Use: Street/Strip
Vehicle Specifications: 1967 Fairlane XL
Style: Modern Cheapass
Engine Details: 428 block +.040, stock Ford guts. Fresh bolts the last time I unbolted it.
                       At least I think so. Ed heads butchered by me. The small Comp Solid Roller.
                       RPM intake, the best looking Holley I have.
Transmission: Home made Jerico 4 Speed 3.08 first gear, Long Gate
Torque converter details (if automatic): See above
Clutch details (if manual): McLeod Adjustable PP, Aluminum Flywheel.
                                       Home made manual linkage
Driveshaft: Steel 3 1/2"
U-joints: 1350
Rear end type: 9 Inch
Differential type: Spool
Gear Ratio: 4.57
Axles: 31
Front tires: 24"
Front wheels: Pro Star
Rear tires: 9 X 28
Rear wheels: Pro Star
Front suspension information: Stock Type with some roller and some stock stuff. QA 1 Shocks
Rear suspension information: Cal Trac springs and bars, QA 1 shocks, home made type track bar
Ready-to-race vehicle weight, including driver: 3900 lbs give or take. It has a 6 point and big heavy square tubes welded in under the 6 point. Full dress interior with matching front recliners
and 5 point harness's. Tunes and GPS if you really get off track.
fallguy72
Re: 1967 Fairlane XL
« Reply #1 on: July 15, 2016, 09:18:55 AM »
Great run!
shady
« Reply #2 on: July 19, 2016, 04:07:10 PM »
I likey. really dig the color (& the time).
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #3 on: July 19, 2016, 05:07:53 PM »
Nice Howie luv the daylight under front tires going to 1/8 mile track this weekend good to talk again
