Author Topic: Electronic points  (Read 5013 times)
tomsfe64
Electronic points
« on: May 20, 2016, 10:18:53 AM »
I have a new fe build that I'm using the original dual point mechanical advance ford distributor.  I replaced the points with pertronix ignitor. The engine runs poorly..won't Rev past 4k or so. Has anyone had probs with this unit?
Re: Electronic points
« Reply #1 on: May 20, 2016, 10:37:54 AM »
The Pertronix is a switch, on or off.
Would have no effect on rpm level.
There are different Pretronix ignitions also, like I, II.
Some with rev limiters. Does yours?
How is it wired into the car?
I always remove the pink wire and run just straight 12 volt or Batt voltage to the ignition.
tomsfe64
« Reply #2 on: May 20, 2016, 10:45:17 AM »
No Rev limiter. But I am using a resistor to the coil. Maybe it's the problem?
« Reply #3 on: May 20, 2016, 11:03:31 AM »
So I went hit refresh on the Pertronix.
Me thinks the resistor to the coil is causing you the grief.
Good grounds and solid connections make for trouble free motoring. ;)
http://www.pertronix.com/docs/instruction-sheets/1181.pdf
TJ
« Reply #4 on: May 20, 2016, 11:59:58 AM »
I ran the Pertronix several years and liked it.  I always used their Flamethrower coil (internally ballasted) so that I didn't need a resister. Years ago I found out the hard way that some coil makes don't last long without a resister.
gdaddy01
« Reply #5 on: May 20, 2016, 05:13:35 PM »
low voltage will make engine die , or it did when my new , rebuilt alternator was no good .
