Author Topic: Stock oil pan ID  (Read 3930 times)
Stock oil pan ID
« on: April 30, 2016, 02:19:43 PM »
I have an oil pan here to put on a nice little 396 inch FE.  I want to buy a pickup to match, but not sure what I have.  I thought it was a truck pan, but it says C7AE-6675, has the factory scraper, a rounded front. I thought the truck pans were squared off and were a 67TE part number.
Anyone know if this is indeed a truck, or is it a car pan? Pics below
Leaning toward truck because I "think" the date code says 1974, but it's real tough to read
Thanks
Re: Stock oil pan ID
« Reply #1 on: April 30, 2016, 02:42:18 PM »
I have the same pan on a 390 that is said to
came out of a 68 Galaxie. And the  64 pan
is like that exept drainplugg location and
no scraper.
So i think it's a a pass.pan
Sorry both my pans have a partial "windage tray"
that your pan missing
« Last Edit: April 30, 2016, 02:45:11 PM by Heo »
« Reply #2 on: April 30, 2016, 05:31:38 PM »
Thanks!  I was told it was a truck pan, and that's what most of the pieces of the motor were off of, but the number threw me off as well as the scraper.
Should be a nice little motor, built it for resale, .004 below deck, C4 crank at .010/010, L2291s, reconditioned stock rods w/ARP bolts, square decked at 10.160, 276/219 .520 hydraulic flat tappet. HV oil pump. Just a good blueprinted healthy pump gas 396 inch FE
« Reply #3 on: April 30, 2016, 07:26:38 PM »
Im building the original PI engine from the 64 Galaxie
much like that but 0 decked at  10.155 280S comp cam
and mildly ported C4 G heads with Cobrajet Valves
And also have a 447 build going on
