Author Topic: sbf-boss-fe parts  (Read 4815 times)
rlsteel
sbf-boss-fe parts
« on: April 24, 2016, 05:54:18 PM »
 ci clevor motor (short block) 302 w block scat 3.400 crank,crowler rods, Ross
boss style pistons,windage tray,hyd roller comp cam,540 lift.looks very nice I bought and
never ran. $1800Sold
> track boss intake $450 (SOLD)
> 1970 DOZE 6090A boss 302 heads complete $1000  (dates 9L4,9G17)(SOLD)
> (SOLD) 2 sets of boss 302 valve covers OE with screws 1 very original,1 has been polished,2
oil caps grommets  both have the factory oil slingers,1 extra set of slingers. several
set of wire holders and brackets one OK stamp. $625(SOLD)
> 1970 boss oil pan nice but baffle trimmed for latter model oil pump pick up.DOOE-66752  Date 03-05-70  2 $225(SOLD)
> boss 302 intake no oil baffle. $375
> milidon 7 qt pan and pick up nice.$150(SOLD)
> new center force clutch set #4900030 $325(SOLD)
> boss 302 flywheel fresh turned. $150(SOLD)
> 2 69-70 console bases  and parts $150 for all(SOLD)
> 1969-70 boss 302 crank std std. will need a polish from setting $400 (SOLD)
> boss 302 gaskets mostly intake and exhaust. $100 for all
> new set of .30 over boss 302 pistons  TRW L-2325 $450(SOLD)
> set of 69-70 boss headers coated $250(SOLD)
> 1/2 inch rear mach one rear sway bar,67-68 front and rear sway bar,s$100-$100
> new crowler solid  cam 274/288  541/526 $125
> several sets of new solid lifters $100 for all(SOLD)
> set of pulleys and brackets and alt for boss motor,not correct numbers wise but
looks and functions as it should $150(SOLD)
> new oil pump and timing chain for boss- sbf.$50(SOLD)
> boss 302-427 valve spring cups 1-set guide plates Boss 302,several sets of push
rods, valve springs, rocker arms,various bolts,valves,etc etc.(lot of value in this
container. $250(SOLD)
> one set of sbf 302 floated rods $50
> one set of Lakewood traction bars ford 9 inch $100(SOLD)
> DO 1970 sbf -boss ? fan $40
> sbf canister fuel pump %40
> 3.50 gear 31 spline posi pumpkin. Truck $300 (SOLD)
complete Paxton set up old  Shelby style 289-302 has carb and fuel pump been setting on
shelf will need serviced $1800(SOLD)
Richmond 5 speed street was in fe powered torino low miles hurst shifter  new yoke chevy
to ford speedometer cable $1800  #7041   710A(SOLD)
lakewood bellhousing and block plate. $275 sbf(SoLD)
Lakewood bellhousing butchered but usable new block plate $150 sbf
all parts are in st louis would sell all  for one price. 20% off if you buy it all
email with question
please email with questions  rlsteel@juno.com      robert
« Last Edit: January 25, 2017, 07:20:38 PM by rlsteel »
Re: sbf-boss-fe parts
« Reply #1 on: April 25, 2016, 06:02:44 AM »
Shoot me pics of the Track Boss intake please...
bryaneidins
« Reply #2 on: April 25, 2016, 02:12:53 PM »
interested in the lakewood bell housings.
Can you email me some pictures please.
bryaneidins70@gmail.com
Thank you.
