Author Topic: WANTED: New mild hydraulic cam, anywhere from 268 adv to 274 adv  (Read 5348 times)
Anyone have something new on the shelf they want to dump?  Looking for something with a 268 to 274 adv intake lobe or anything in between.  This is for a budget short block with no home as of yet.  Wide range of "good enough"
Not really concerned with LSA, ICL, .050, just looking for new and cheap :)
GJCAT427
Re: WANTED: New mild hydraulic cam, anywhere from 268 adv to 274 adv
« Reply #1 on: April 20, 2016, 11:22:15 AM »
Let me check one I have . It is slightly used. I will get back to you tonight.
GJCAT427
« Reply #2 on: April 20, 2016, 05:40:06 PM »
Ross, I have a Crower 280HP grind that has the following Adv intake 280* duration, .537lift. exhaust 286* duration,.551 lift. 112* lobe separation.  If you go to the Crower cam specs its part # 16241 it shows the full cam card. Garry
« Reply #3 on: April 21, 2016, 06:32:59 AM »
Garry, thanks a bunch but I think that's just a little too much duration and late ICL for what I am trying to do.  I do appreciate you chasing it down though.
Tony Fritz
« Reply #4 on: April 21, 2016, 11:15:47 AM »
Ross,
I have a new Crane Hydraulic Roller Cam pn 349521 HR-222/332-2S-10. Specs are:
Adv Dur - 284 - I , 290 - E
Dur @.050 - 222 - I , 226 - E
Lift - 584 - I , 607 - E
110 CL
2500-6000 RPM range.
New in the box. Make me a reasonable offer. I am going to the FE Race & Reunion and can bring it to Beaver Springs.
Thanks, Tony
chris_r
« Reply #5 on: April 22, 2016, 09:49:49 PM »
i have a new comp cam that is 281 on the intake if that will work?
« Reply #6 on: April 23, 2016, 03:16:27 AM »
Thanks guys, I ended up finding one, went with a single pattern 276 adv, 219 @ .050, 110 on 106, .530 lift.  Should be a nice little cam for this 390
I appreciate everyone responding to help
