Author Topic: carbs for a Ford medium riser 2x4 intake  (Read 7458 times)
jholmes217
« on: April 18, 2016, 06:07:23 PM »
Picked up a 2x4 Fomoco 2x4 medium riser intake.  I can get a pair Holley 1850-2 600 cfm carbs for a good price.  What would be required to get these to work with this intake manifold?
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
Re: carbs for a Ford medium riser 2x4 intake
« Reply #1 on: April 18, 2016, 06:32:02 PM »
I have the 1850's on mine ..... secondary carb needs stud mounted in a lower hole for the progressive linkage to work and needs the base plate clearenced for the throttle linkage to bolt up ......
Both carbs need a vaccum balance fitting to connect both carbs so the secondary's open together ..... that's pretty much it
heres a link that gets more detailed
http://www.ford-trucks.com/forums/1004931-how-i-modded-regular-holleys-for-2x4-use.html
jholmes217
« Reply #2 on: April 18, 2016, 07:19:18 PM »
Thanks.  Reproduction BJ/BK carbs are out of my price range.  Holley 1850s are a dime a dozen on Craigsist.
Jeff
Olympia WA. area
jholmes217
« Reply #3 on: April 18, 2016, 08:16:22 PM »
What size jets did you use?
Jeff
Olympia WA. area
« Reply #4 on: April 19, 2016, 09:37:54 AM »
I started with stock size 66's and ended up 68's on my 416
jholmes217
« Reply #5 on: April 19, 2016, 09:48:10 AM »
Thanks.  My car is a 428, so I'll try starting with 68's.  Do your carbs have the stock metering plates in the secondaries, and did you go with light springs?
Jeff
Olympia WA. area
« Reply #6 on: April 19, 2016, 11:43:40 AM »
stock blocks and plates .... I went with the light spring in both
jholmes217
« Reply #7 on: April 19, 2016, 12:26:49 PM »
Thanks so much for the information.  There is a guy that has a pair of Holley 1850-2 carbs local for $100.  Sounds like I should jump on that, and do the modifications.
The benefit of my 1969 Mach 1 being a Q code 428 Cobra Jet car is I don't have to worry about manifolds and carbs working with a shaker hood scoop.  A previous owner of my car also evidently switched hood scoop emblems when he went looking for a street race.  I found 351 emblems in the glove box!
Jeff
Olympia WA. area
shady
« Reply #8 on: April 19, 2016, 01:23:59 PM »
sneaky...I ran a boss 302 in a comet that I had put some 260 tags on it from a fairlane.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #9 on: April 19, 2016, 01:24:09 PM »
I haven't run them yet, but apparently this is what QF thinks:
jholmes217
« Reply #10 on: April 19, 2016, 04:28:27 PM »
Good info Drew!  Thanks for posting!
Jeff
Olympia WA. area
427LX
« Reply #11 on: April 19, 2016, 05:41:50 PM »
I setup a pair of 1850's on my 427W recently and if you are working with used carbs make sure you check the primary and secondary carb body sealing areas for being flat. Most will have a sunken area in the middle and this can cause gasket sealing problems that can affect performance.
On my engine which is in the 550HP area,I ended up with 67 Primary jet and 68 jets in a jet plate setup.
Also don't be afraid to try a 8.5 PV during your tuning as this helped bring the extra fuel in a bit earlier during heavy accel without secondary opening.
jholmes217
« Reply #12 on: April 29, 2016, 09:47:48 AM »
If running a distributor with vacuum advance, should I put a cap on it, run it to the front carb, or run it to the back carb (closest to firewall)?
Jeff
Olympia WA. area
« Reply #13 on: April 29, 2016, 09:52:04 AM »
front carb if your using progressive linkage
