FE Technical Forum
427 Heat Riser Dimension
Topic: 427 Heat Riser Dimension (Read 3062 times)
The Real McCoy
Full Member
April 14, 2016, 07:51:29 PM »
Anyone know how thick the heat riser is on a 63 427 cast iron exhaust headers setup. I'm looking at getting an H pipe made up and the manufacturer builds to factory specs which means I need to fabricate a spacer for the right side header.
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so." Mark Twain
FE Technical Forum
