Author Topic: Did FoMoCo deliver "steel" flywheels with any FE's or other big blocks?  (Read 3088 times)
Qikbbstang
For sure 428SCJ's came with cast iron flywheels since they had the counter balance weight and casting numbers.  SCJ's were actually fairly tame with flat tappet std 390GT/428CJ Cams the rev's were not exceeding 6,000 at most.  But what about 2x4V 427s? ............... I've seen enough examples of T-Bolt bellhousings to know rev's were a concern. How about lightweight Galaxie's etc
Let's not forget Boss 302's and Boss 351's that I'm pretty sure had factory Rev Limiter's set over 6,000.
A 6,000 rpm flywheel ought to be capable of cutting through a car - did Ford use steel?
« Last Edit: April 14, 2016, 06:46:23 PM by Qikbbstang »
