Author Topic: Let's discuss gasket sealers  (Read 4443 times)
jgkurz
« on: March 31, 2016, 03:25:02 PM »
Hi Folks,
I got my stroker FE long block back and so it's time to assemble. Yay! I've built many different engines but never an FE. I would like to take a poll on the various sealants for each location below. I use different sealant depending on the use including Ford TA31 RTV , Gasgacinch, Permatex brown Form-A-Gasket, and Permatex Red RTV. I apply sealant very conservatively at all locations.
Please critique. Thank you!
•   Intake manifold gaskets - Ford TA31 on ends and on china wall seals
•   Oil pan w/windage - Gasgacinch (I like TA31 but I'd never get the pan off)
•   Oil filter adapter - Very light Form-A-Gasket
•   Oil pump pickup - Very light Form-A-Gasket
•   Thermostat - TA31
•   Waterpump - TA31
•   Timing chain cover - TA31
•   Fuel Pump - Form-A-Gasket
« Last Edit: March 31, 2016, 04:32:43 PM by jgkurz »
wayne
Re: Let's discuss gasket sealers
« Reply #1 on: March 31, 2016, 04:22:03 PM »
I just use spray on copper coat with a small bit of rtv on the end seals of the intake.
jgkurz
« Reply #2 on: March 31, 2016, 04:42:09 PM »
I hadn't thought to use a copper coating on the intake gaskets. It's worked well for you?
wayne
« Reply #3 on: April 01, 2016, 06:28:16 AM »
Yes i have good luck with it if you have to take it back apart its easy i am not to big on sealers ford did not use them much when new.
