Author Topic: Intake Manifold Port Balance  (Read 3688 times)
FirstEliminator
« on: March 06, 2016, 09:46:35 PM »
    Hey guys,
       How important is it to have the intake manifold flow balanced between all the ports? I've recently read something about balancing the flow of the intake and I can't remember which intake it was that one of the ports was way off. With some intake work, all the ports were pretty close in flow. I believe it was a manifold that Blair Patrick was working with.
   Stock or mild engines seem to just have the intake bolted on in most cases. Does the port balance have much effect on low rpm or part throttle situations?
    Is the Edelbrock Performer RPM close to balanced out of the box?
   thanks,
      Mark
   thanks,
      Mark
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
427LX
Re: Intake Manifold Port Balance
« Reply #1 on: March 06, 2016, 11:19:35 PM »
If you can get all the ports to flow as much as the highest flowing port and the fuel evenly distributed...more HP!
You would need to send it to a good porting shop with ability to flow test it.
« Reply #2 on: March 06, 2016, 11:19:52 PM »
There is quite a difference in flow between the upper plane and lower plane runners on the RPM.  I always try to balance them to within a few cfm of each other when porting them.  I port the intake to 110% of the head flow for the street, and 120% for street/drag race.  Always seems to work on the dyno testing that I have seen afterwards.  Joe-JDC
