Author Topic: FE adapter/351C efi tunnel ram done  (Read 20656 times)
cobracammer
Re: FE adapter/351C efi tunnel ram done
« Reply #15 on: August 31, 2016, 01:26:13 PM »
Yes sir.  Let the fun begin!  Since you are at this point, I thought I would ask.  Do you find that:   You go through the ecu setup screens.... adjusting the idle screw to get into the target area on the handheld, and finally save it all.  Car is warmed up at this point as it has to reach temp before it will let you continue....  then you can star the car and shut it off easily!  Then the next day, you try to start and it does not start up as easily as when its warm?  I am not sure if you have had this problem, or if its part of the EFI's "Charm".
Jason
newfalconowner
« Reply #16 on: August 31, 2016, 02:32:22 PM »
yeah I found that problem, restarting the next day after setting throttle adjustment. it eventually started ok and once warm fired right up again.. Something I will have to look into again as I haven't started it since then..
cobracammer
« Reply #17 on: September 01, 2016, 07:39:28 AM »
For your reading enjoyment and or pleasure  :0).......  we are not alone  LOL
http://www.dragzine.com/news/a-fast-ez-efi-full-color-handheld-upgrade-that-youll-want-to-do/
Jason
newfalconowner
« Reply #18 on: September 01, 2016, 02:40:03 PM »
I saw this in your post last nite and commented there as well.. I just might have to try and get one of those handhelds..
newfalconowner
« Reply #19 on: October 09, 2016, 07:33:31 PM »
how the tunnel ram looks, shes all done
newfalconowner
« Reply #20 on: March 25, 2017, 07:29:52 PM »
i got a new MSD 8594 distributor and the cap hit the IAC on the throttle body,
without spending any more money on this, I choose to raise the plenum abit so took it to work and made a new box. Test fitted it today and I have lots of clearance now.
bit higher then I really wanted out of the hood but it will do
newfalconowner
« Reply #21 on: March 26, 2017, 06:39:31 PM »
put the new plug wire ends on, going to fit perfect and lots of room to remove cap if I ever need to
gdaddy01
« Reply #22 on: March 26, 2017, 08:10:15 PM »
nice , been watching your build for awhile , good work
newfalconowner
« Reply #23 on: April 23, 2017, 07:15:33 PM »
video with the taller plenum, will get it tuned up and out of the garage when its warmed up outside
https://www.youtube.com/watch?v=Wpoq6pQCVaM
cobracammer
« Reply #24 on: April 24, 2017, 11:34:52 AM »
Nice!  Getting Closer!
Jason
62Falcon390
« Reply #25 on: July 31, 2018, 07:14:00 PM »
thought I would update this instead of starting over.
I revamped the top plenum for the 3rd time, and its stays now.. I got my engine rebuilt over winter and got it back end of may. First car show was June so I did a mad panic to get it all together after a long winter thrash.
I have been driving the car constantly since June 2nd, about 4 times a week, and its running flawlessly every time. Car runs and drives awesome, no hesitation on the tunnel ram, instant pedal.. The Fast efi is learning all the time, and works perfect. I have close to 700 miles on the car now,, and have never once left stranded. I am very impressed and happy with the engine and efi.
Bolted to Floor
« Reply #27 on: July 31, 2018, 11:33:39 PM »
Thanks for sharing the progress and the ride. Looks and sounds great.
« Reply #28 on: August 01, 2018, 02:31:16 AM »
I guess that Falcon moves  8)
62Falcon390
« Reply #29 on: October 23, 2018, 05:58:47 PM »
