Author Topic: Suggested valve springs with Comp 294S, Ed heads and Pumpbuilder rockers  (Read 8777 times)
Pentroof
I'd like to get in the ballpark before breaking out the measurement tools and shims. Is there a set of springs out there that are a known bolt in and go with this combination that won't pull my rocker shaft studs or float the valves?
Thanks
I think Comp recommends their 924 springs for that cam, but I have run the Comp 930 springs on that cam with no problems, up to 6000 RPM with no valve float.  I imagine that they would go higher than 6000 if necessary.  Here's a link to the springs on Summit's web site:
http://www.summitracing.com/search/?keyword=cca-930-16&dds=1
If I recall correctly, they were a direct replacement for the springs that come with the Edelbrock heads.  I'm pretty sure I used the same seats, retainers, locks, everything.  You would, of course, want to set up the springs with whatever shims were required.
« Last Edit: April 07, 2011, 09:05:27 PM by jayb »
