Author Topic: Valve covers for T&D and booster.  (Read 9170 times)
Landlubberatsea
  • Jan
« on: February 18, 2016, 02:00:34 PM »
Hi
Anyone who knows if these covers will both accomodate T&D rockers (street version) and clear the brake booster on a 445 in a -68 Torino GT?
http://www.carlsfordparts.com/parts_images/specials/428_CJ_finned%20Valve%20Covers.JPG
If they clear the booster but not the rockers, would it then be possible to make them do it by either modifying the baffles or use a thicker gasket/spacer (and still clear the booster)?
Grateful for any input, thanks /Jan
-68 Torino GT with a 390 that turned out to be a 360 but now is becoming a 445....
jholmes217
Re: Valve covers for T&D and booster.
« Reply #1 on: February 18, 2016, 02:19:16 PM »
They look like 69-70 428 Cobra Jet valve covers.  They fit on my 69 Mustang with power brakes with the POPs rocker system and end stands, but I had to take the baffles out of the valve covers.  Some have "persuaded" the baffles to work with a hammer, or made new baffles.  I chose to run a twist in breather on one side, and a twist in PCV breather on the other.  Both breathers have baffles in them, so I don't need the baffles in the valve covers.
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
« Reply #2 on: February 18, 2016, 06:41:53 PM »
They will clear the booster fine because they are a re-pop of the original CJ valve covers. They have a cut back area on one end that coincides with the boosters. And they do clear most all of the aftermarket rockers and end stands, but I don't know specifically about the T&D Street because I've never used them. I have run both POPs and Oregon Cams systems with Harland Sharp rockers under those covers without issues, other than the above mentioned baffles.
jgkurz
« Reply #3 on: February 18, 2016, 07:05:49 PM »
I'll be using the CJ valve covers with T&D rockers soon. I just need the rockers to deliver so I can mock them up. I intend to run some sort of baffling in the valve covers. I may need to fab my own baffles but I expect them to fit otherwise.
Dumpling
« Reply #4 on: February 18, 2016, 09:22:34 PM »
I have PCV' s in both valve covers, with a breather on the front of the intake.  Is this a bad thing?
jholmes217
« Reply #5 on: February 19, 2016, 10:49:07 AM »
Another thing you can do if you prefer to leave the baffles in the valve covers is install valve cover spacers.  Dennis at DSC Motorsports has them for $135.  Here's a link:  http://www.dscmotorsport.com/asp/Products/popup_PartDetails.asp?PartID=1140
« Last Edit: February 19, 2016, 01:48:05 PM by jholmes217 »
Jeff
Olympia WA. area
Landlubberatsea
  • Jan
« Reply #6 on: February 19, 2016, 11:02:38 AM »
Thanks for all the replies and input, much appreciated! Hope someone is willing to help me with a few more questions  ;)
So the 428 CJ covers will clear the booster but a bit uncertainty about the rockers. Could the pentroof covers then be an alternative or are they to tall for the booster?
http://www.dscmotorsport.com/asp/Products/popup_PartDetails.asp?PartID=743
I have thought of spacers as well and maybe the half height is the best solution. It's just that they are kind of pricey for me right now. I wonder if a thicker gasket does the trick for rocker clearance under the CJ's, and which gaskets are then the best?
Also, I remember reading that the PCV valves are of different size and that it is important to not get a too small one. How do I now which PCV valve that is the correct for my engine, does the increase in cubes (390/445) affect that?
Once again, many thanks for the replies so far/Jan
jholmes217
« Reply #7 on: February 19, 2016, 11:53:38 AM »
Give Dennis at DSC a call.  Those pent roof valve covers can be ordered with a brake booster modification where they grind down the corner so it will clear the booster.  I believe it is a $15 charge, but I may be wrong.  Best to call Dennis and ask him.  My 428 Cobra Jet is bored .060, so I believe that equals like 439 cubic inches.  It seems to run fine with a parts house PCV listed for the 428 Cobra Jet.  http://www.autozone.com/external-engine/pcv-valve/az-filters-pcv-valve/ford/mustang/1969/8-cylinders-q-7-0l-4bl-ohv-cj-hp/918519_0_0/?checkfit=true
Jeff
Olympia WA. area
Landlubberatsea
  • Jan
« Reply #8 on: February 19, 2016, 01:02:14 PM »
Well Jeff, that sure sounds interesting, I'll give him a call. Many thanks for your help.
jholmes217
« Reply #9 on: February 22, 2016, 07:28:17 AM »
Your welcome!  Let us know what he says.
Jeff
Olympia WA. area
Landlubberatsea
  • Jan
« Reply #10 on: February 29, 2016, 04:17:55 PM »
Called Dennis but unfortunatelly he couldn't help with covers. I ordered a set of half height spacers though so I will work something out one way or another.
Well at least I learned that next time I check clearances before I remove the engine and send it away...... :P :)
