Author Topic: 66 mustang 428  (Read 15899 times)
427Fastback
66 mustang 428
« on: February 18, 2016, 12:27:52 AM »
I haven't talked about this project much..While my 68 is in the paint shop I am keeping myself challenged by putting a 428CJ and 4spd in a 66 Fastback..Altho I have changed the front suspension the owner wants the towers left in the car..I will talk about that later.
Engine is a dual quad 428CJ with a CC 268H and a set of comp/dove roller rockers..I am even using CJ exhaust manifolds.Trans is a 390 small input wide ratio and I narrowed up a 9" housing and it has 3.7's with a new traction loc..
Finished bolting the eng/trans together today and will probably install it tomorrow..
Car will be 100% street driven...I have been trying to set this project in motion for over a decade.Now I have free reign on it...
Interesting side note...I am not to over do the details or make it look too pretty..The owner wants it to look like it was done a while ago..Its getting lots of used parts and the paint job is going to be distressed right away....Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
Re: 66 mustang 428
« Reply #1 on: February 18, 2016, 07:26:26 AM »
Waaaay interested in what you're doing as I am doing the same thing to the same car.
However I took out the towers and completely changed the bottom of the car.
Biggest problem for me is second guessing my thought process from years ago.
Re: 66 mustang 428
« Reply #2 on: February 18, 2016, 09:35:49 AM »
Love the distressed idea. The heads by the exhausts will burn off that blue paint in a hurry. Maybe spray some oil from a spray bottle here and there under the hood. I'd not worry about an FE not leaking oil from underneath! Maybe pour a tad of gas on the cold intake and let it evaporate overnight. Or, spray some clear flat on the black painted sheetmetal to dull it. hah!
Re: 66 mustang 428
« Reply #3 on: February 18, 2016, 09:55:11 AM »
What intake is that?
Re: 66 mustang 428
« Reply #4 on: February 18, 2016, 10:22:53 AM »
Looks like one of the new Edelbrock 2X4s, for use with Edelbrock carbs.  It performed very well in my tests, at least at the lower horsepower levels.  I'm very curious about the engine compartment mods on this project, Cory...
427Fastback
Re: 66 mustang 428
« Reply #5 on: February 18, 2016, 12:39:43 PM »
Good to hear the manifold performs well.As the heads have had all the exhaust seats replaced at one time I have kept the spring pressure conservative and the RPM will be controlled.CJ heads do not take seats well..
I only have a moment so I will show some pics of the towers.They were incorrectly removed by someone else.I will show more later today.I cut each tower into about 8 pcs and carefully fit back together.Goal was to have them look semi normal and the export brace must fit back on and be used..
Re: 66 mustang 428
« Reply #6 on: February 18, 2016, 01:28:02 PM »
Now Im more curious about the decision to keep the towers with adding the crossmember for steering.
I assume that he/you felt that the added crossmember would strengthen the front end as well as give you a good rack mount. And you could go with the new strut style suspension instead of mustang twoing it?
Re: 66 mustang 428
« Reply #7 on: February 18, 2016, 01:32:31 PM »
Yeah, it looked new, I thought the only new one was the Air Gap.....  I'll need to recheck your book.  Thanks!
427Fastback
Re: 66 mustang 428
« Reply #8 on: February 18, 2016, 01:49:51 PM »
Putting the towers back in is strictly for deception...Not trying to hide anything..When you open the hood it will look stock but when you look closer you will figure it out...
I have converted three Mustangs to rack and pinion.I always put some of the tower or a hand made version of the tower back in so I can put all the braces back in..
I and the customer actually hate the look of Mustangs with flat sided engine bays..(The Eleanwhore look)It would have been easier to hand make something but he really wants the stock export brace back in...
Re: 66 mustang 428
« Reply #9 on: February 18, 2016, 02:08:19 PM »
Hah
Then you're gonna hate mine. ;)
Not "elewhore" but flat sides and flattened firewall.
No deception anywhere.
Re: 66 mustang 428
« Reply #10 on: February 18, 2016, 02:34:13 PM »
Now that's a cool idea to get the stock look. I admire though all the work you did to cut up all that metal, weld it up and finish it to look factory. Very nice!
Re: 66 mustang 428
« Reply #11 on: February 18, 2016, 06:35:41 PM »
You're going to have to do some serious uglying to that engine, 'cause it looks pretty good to me. I've got a couple of pretty ugly 360's sitting around that I could trade ya, if it'd help ;D
As much as I cuss those pesky shock towers, I agree that the cars just don't look right without them. A cut back or Boss 9 version is the best of both worlds, in my opinion. Looks like you had a pretty clean car to start with, and that's always a big plus. And as always, you do really nice work, Cory.
427Fastback
Re: 66 mustang 428
« Reply #12 on: February 18, 2016, 09:13:37 PM »
The rad cradle was also sectioned and a 67/68 center was put in to use a stock 67/68 FE rad..I am also using stock(modified)68BB rad mounts.I reworked the stock battery box to fit into its now limited space..
The project was started on by a very well know shops head fabricator.He managed to weld the whole front crossmember and attaching parts in 1 1/4 inches to far forward.He also hacked the towers out to the point I almost had to scrap them and it was nearly impossible to get them back in and lined up again..
More later
Re: 66 mustang 428
« Reply #13 on: February 18, 2016, 09:18:48 PM »
Was that crack fabricator from a Chevy shop?   ;)
427Fastback
Re: 66 mustang 428
« Reply #14 on: February 18, 2016, 09:54:40 PM »
He was actually from a well know shop that builds those high($$$$) dollar project cars for people.The shop closed down (wonder why) and the work was done at the owners house.Dont know what happened or how he got it so far off but he certainly F**ked up....When the mistake was pointed out to him he was never seen again...
First job for me was to cut it all out and start over....
