Author Topic: Looking for a timing cover to match a 427 Block with Date code of 3-J-20.  (Read 5646 times)
garyv
Let me know if anyone has anything.
Thanks
garyv
427Fastback
I have two C3 timing covers...I don't see a date code on either one...The one off my 427 has 427R stamped in the top (????) no date codes that I can see tho...
1936 Diamond T 212BD
1990 Grizzly pick-up
garyv
Re: Looking for a timing cover to match a 427 Block with Date code of 3-J-20.
« Reply #2 on: February 01, 2016, 07:54:49 AM »
I don't think they have a date code other than C3 or C4.
Probably either would be correct.
From what I have found the "J" heads date this as a 64 1/2 engine
let me know if you want to sell one.
thanks
garyv
427Fastback
« Reply #3 on: February 02, 2016, 03:13:16 PM »
I don't need the blue C3 one.Timing pointer is a bit different than my other C3 cover..Needs a good cleaning but I don't see any stripped or damaged holes.Was on a CJ I am doing so I yanked it off and put a C8 cover on it..
garyv
« Reply #4 on: February 02, 2016, 04:23:14 PM »
What you want for it?
garyv
427Fastback
« Reply #5 on: February 03, 2016, 01:26:41 AM »
Thinking $40.00 plus some shipping.....Keep in mind I am up in BC Canada.......Cory
garyv
« Reply #6 on: February 03, 2016, 07:04:10 AM »
Cory my zip is 25177 I'm in WV.
if you don't mind check to see what shipping would be
I have one coming from another member and I'll look it over.
If it doesn't work out I'll get back with you.
Chances are I still may take it depending on shipping charges.
Thanks
garyv
« Last Edit: February 03, 2016, 09:26:24 AM by garyv »
