Author Topic: Experimental 727 CID V-12 Cammer  (Read 10155 times)
Hemi Joel
« on: March 18, 2012, 12:18:36 AM »
Have you ever seen this before?  I like it. I want one!
Re: Experimental 727 CID V-12 Cammer
« Reply #1 on: March 18, 2012, 08:08:47 AM »
I think that was made in the "photoshop".  I would like to hear what a 12 cylinder FE sounds like at 7000+ rpm though.   ;D
paulie
« Reply #2 on: March 18, 2012, 08:57:53 AM »
It's been around for quite a few years now. Still, it's an amazing pic that shows just how well Photoshop can change a pic, as one really needs to zoom in a ton to see the few wavy lines that gives it away (see valve cover fins).
« Last Edit: March 18, 2012, 01:24:00 PM by machoneman »
« Reply #3 on: March 18, 2012, 12:52:03 PM »
Naw, it's real!! The wavy lines are simply where Razor welded in the section of cam cover. ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #4 on: March 18, 2012, 01:10:22 PM »
Hemi Joel is a Mopar guy, so of course he would be fooled by that  :D
Hemi Joel
« Reply #5 on: March 19, 2012, 01:04:01 PM »
I figured it was probably fake. Because if it really existed, I know that Jay would have one!
« Last Edit: March 19, 2012, 01:07:04 PM by Hemi Joel »
« Reply #6 on: March 19, 2012, 01:31:39 PM »
I would think it would be easier to make a V16, based off of a V8, than it would be to make a V12.   Basically just two of almost everything.  It seems like it would be difficult to make a good intake manifold for an FE based V12, for instance.    I dunno.
paulie
« Reply #7 on: March 19, 2012, 02:05:32 PM »
Wow, now there's an idea: imagine how heavy even an aluminum V-12 or V-16 non-SOHC FE intake would be!
Boggles the mind, indeed! Would probably take 1/2 the aluminum reserves in the western world to cast it....LOL!
Garyford
« Reply #8 on: March 29, 2012, 06:00:19 PM »
paulie
A V-12 might not sound as cool as one hopes. At this you- tube link is a Falconer V-12 which I believe is based on small block $hevy  http://www.youtube.com/watch?v=mHTTBi4vjwQ
« Reply #9 on: March 29, 2012, 07:46:23 PM »
paulie
All kidding aside, Razor did the welding to join the two blocks and the four heads necessary to make the V-12 engine that went in the 'GT-90' Ford. One cylinder off each side of the front of one block and the same off the rear of another then weld the two six cylinder blocks together. Same process for the heads. Google 'GT-90' for more information.
mammyjammer
« Reply #10 on: March 29, 2012, 08:42:39 PM »
I think the Falconer is  based off the BBC, and I almost hate to say it , but a Thunder Mustang sounds amazing in the air.
 It as that "different" tone , like a  boat has when under load.
A 12 cyl Cammer would really make those Mustangs thunder!
