FE Technical Forum
DannyBee crankshaft gear
Topic: DannyBee crankshaft gear (Read 4480 times)
January 20, 2016, 09:11:38 PM »
Can anyone tell my how many teeth is on the crank gear ?
Keith. KB MAX Racing.
57 lima bean
Re: DannyBee crankshaft gear
Reply #1 on:
January 21, 2016, 11:20:10 AM »
Half as many that are on the cam gear... :)Looked at a shot of the belt set up.Hard to count but many.
Reply #2 on:
January 21, 2016, 12:32:07 PM »
Ok, I'll find a decent pict o the cam gear then maybe. Just was looking for the easy way out.
XR7
Reply #3 on:
January 21, 2016, 12:35:02 PM »
Are you still trying to use a Cleveland set-up on the FE? I do think the cam to crank bore centerline height dimension is the same.
Administrator
Reply #4 on:
January 21, 2016, 01:17:33 PM »
Keith, I've got a picture of the Danny Bee belt drive in the thread below. You've got to zoom in to see it, but you can count the number of teeth on the cam gear if you are careful. Using 57 Lima Bean's brilliant deduction (
), there are 30 teeth on the Danny Bee crank gear.
http://fepower.net/simplemachinesforum/index.php?topic=168.0
Reply #5 on:
January 21, 2016, 01:21:06 PM »
Use 29 teeth so the CAM opens faster
Reply #6 on:
January 21, 2016, 02:06:35 PM »
Thanks guys, I had just zoomed in on your cam gear from the same post Jay. Shoulda done that to start with but I was. Don't lazy I guess.
FE and cleveland both have same center to center. 5.044
FE Technical Forum
